Threads: 32,385
Total Online: 554
Old May 2nd, 2005, 02:05 PM   #1
i'm pumped, i have a goal for tonite and i wanna get it done. then the first lug i want to remover is rounded out and i cant get a grip on it with a 19mm, or a lug wrench. i tried a vice grip and hammer and get nowhere. so short of cutting it off.....any ideas....i can still get this done.....but i gotta get that lug off
Old May 2nd, 2005, 02:10 PM   #2
Maybe try finding a slightly smaller 12pt socket that you can pound onto the lug. [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img]
Old May 2nd, 2005, 02:11 PM   #3
57Drag
57Drag's Avatar
I have use a air chissel as long as it is not very sharp it will lossen it enough to get it off....After breaking it loose I hammered a old socket that was too small on it.My dad has welded sockets to them on 62 IH Scout that he got from the junkyard.....Donald
57Drag is offline   Reply With Quote
Old May 2nd, 2005, 02:14 PM   #4
RATRODVW
You've got a newfangled welder right? Weld an old socket or piece of scrap metal to it...
RATRODVW is offline   Reply With Quote
Old May 2nd, 2005, 02:17 PM   #5
I ahve had luck welding a bigger nut onto the old rounded off. Get a large nut that will just fit over the rounded off one and puddle weld that sucker on there.
You now have a much large nut to grab onto plus the heat of the welding will likely have helped loosen everything up.
Good luck.
Old May 2nd, 2005, 02:22 PM   #6
busguy71
busguy71's Avatar
run a bead of weld with your MIG , or a few beads, on the lugnut. The heat might help losen the nut. A teacher of mine used this trick on stuck races or bearings or something, maybe it'll work for you.
Or, if you wait til wednesday [img]style_emoticons/<#EMO_DIR#>/sad.gif[/img] I'll bring my oxy acetylene up and heat it for you
Everyone sucks but me
X- GT40 builder
busguy71 is offline   Reply With Quote
Old May 2nd, 2005, 02:26 PM   #7
I bought a car with theft lock lug nuts but the seller didn't have the key. I welded one of those thick plumbing pipes I often use as a cheater pipe, turn the pipe and the nut's loose. Break the bead then remove by hand.
Old May 2nd, 2005, 02:30 PM   #8
wow - that's why i love this place.....a ton of answers in a matter of moments.....thanx guys
Old May 2nd, 2005, 02:41 PM   #9
Did you get it off yet??? [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
Old May 2nd, 2005, 02:53 PM   #10
mrs.57Drag
Hope you get your nut off [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img]
Annie
mrs.57Drag is offline   Reply With Quote
Old May 2nd, 2005, 03:04 PM   #11
57Drag
57Drag's Avatar
Don't she know this is a family forumn [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img] ......Donald
Old May 2nd, 2005, 03:13 PM   #12
Sounds like you definately found a keeper!!!
Old May 2nd, 2005, 03:35 PM   #13
NICKSTER
Guest
Posts: n/a
Not yet, but I might need to re-visit your GNF pictures! [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
Old May 2nd, 2005, 06:27 PM   #14
did dan get his nut off yet?
Old May 2nd, 2005, 06:31 PM   #15
Leave it to Dan to bust a nut!
Old May 2nd, 2005, 08:44 PM   #16
BIG BAD BUG
If all else fails...
Nut Splitter...!!!
$7.99
http://www.pricegrabber.com/search_getprod...sterid=1583009/
[img]style_emoticons/<#EMO_DIR#>/hello.gif[/img]
Volksrods.com
~We'll get you kicked outta your house.
BIG BAD BUG is offline   Reply With Quote
Old May 2nd, 2005, 08:48 PM   #17
spraypaintspecial
spraypaintspecial's Avatar
HAHAHA... I had the same problem...ROunded one off pretty bad. The damn thing was stuck as hell.... Tried a huge breaker bar, but the front tire spun and the nut didn't Budge. I was trying to avoid people slamming me cause I thought it had been posted before, haha [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img] . When I disasembled my beam, I took off the drums, with the wheel still bolted to it. [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img]
PANHANDLE PANSCRAPERS
http://img.photobucket.com/albums/v2...69/BlogSig.jpg
spraypaintspecial is offline   Reply With Quote
Old May 2nd, 2005, 08:56 PM   #18
thrillcrazyspeed
thrillcrazyspeed's Avatar
nut splitters rule, don't know how I ever got around without one
myspace: http://www.myspace.com/thrillcrazyspeed
I'm closing out VW parts galore, let me know what you need most...if you end up in the Greeley, CO area email me, you can come browse our warehouse.
Wear Blue Pants!!!
thrillcrazyspeed is offline   Reply With Quote
Old May 3rd, 2005, 03:20 AM   #19
dan doesnt want to talk about the current results.....needless to say, the nut isnt off yet (well, at least what is left of it) DOH
Old May 3rd, 2005, 05:04 PM   #20
Originally posted by BIG BAD BUG@May 3 2005, 12:44 AM
$7.99
those should be called a 'divorce' [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
Old May 3rd, 2005, 05:39 PM   #21
I got a wheel with 4 lug bolts stuck in the drum. Jammed on there and even a impact ratchet won't break them loose.
I am gonna try some heat and if that doesn't do it. I will just yank the drum off and throw the wheel and all away.
I just can't bring myself to spend that much time on it.
Can't use the lugs don't want the wheel.... The drum might still be good though. [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img]
Old May 3rd, 2005, 06:20 PM   #22
it's off....i ended up grinding the head down till the wheel came off, and then it turned off with avice grip
Old May 3rd, 2005, 08:53 PM   #23
BIG BAD BUG
Originally posted by crack monkey+May 3 2005, 05:04 PM--><div class='quotetop'>QUOTE(crack monkey @ May 3 2005, 05:04 PM)</div><div class='quotemain'><!--QuoteBegin-BIG BAD BUG@May 3 2005, 12:44 AM
$7.99
[/b][/quote]
Actually, I think they're more like a Marrige aren't they...
I know one of my ex-g/f's was a Ball Breaker... [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
Volksrods.com
Old May 3rd, 2005, 09:00 PM   #24
PAPA_SMURF
PAPA_SMURF's Avatar
when my adapters had the lugs spin on me I did it two different ways...
1. 12 pt socket I didnt want, and hammered the bitch on there and used an impact.
2. cut a chunk out with a die grinder then use your air chisel to get it to back off.
..the first idea is quicker.
...Joey
66 schwinn, 04 Jetta
vwclubofhawaii.ning.com
