Threads: 32,380
Total Online: 211
Old August 5th, 2003, 08:07 AM   #1
type3rod
I know that when you cut off the roof of a vw you need supprt(roof=alot of support) and that means braces.Wondering were everyone puts theres?????
Pistol Pete get well soon!!!!
type3rod is offline
Old August 5th, 2003, 08:10 AM   #2
Mr. Electric Wizard
On the pillars, behind the doors, going from one side to the other...
A roll cage helps a lot too...
<a href=\'http://www.aircoolers.org\' target=\'_blank\'>Aircoolers VW Gang[/url]
1966 Deluxe Microbus
Mr. Electric Wizard is offline
Old August 5th, 2003, 08:33 AM   #3
vwfye
there are several ways to do this...
my car has two 2x4 box steel runners from one end to the other about 18 inches apart. then i have a hoop roll bar that is tied into the body at 6 points. car does not flex, and is stiffer than when the roof/glass were there.
Brian <a href=\'http://www.geocities.com/menacefye\' target=\'_blank\'>My Life on Display...[/url]
Early 64 Notch
Late 64 Mid-engine Notch Speedster
73 Squareback
72 Kombi
75 Westy
vwfye is offline
Old August 5th, 2003, 08:38 AM   #4
vwfye
this was the starting point for the midengine notch speedster... can you say ouch?
Early 64 Notch
73 Squareback
72 Kombi
75 Westy
vwfye is offline
Old August 5th, 2003, 10:55 AM   #5
Mr. Electric Wizard
yup,
i suppose that's one way to do it... :D
Old August 5th, 2003, 11:05 AM   #6
type3rod
I want to have this be my daily driver and would like to avoid a roll cage.Also I am doing(hopefully) a carson top and would like to keep the backseat availible. ??????
type3rod is offline
Old August 5th, 2003, 11:13 AM   #7
Mr. Electric Wizard
the box steel runners sounds like the way to go then... after all, on a vert beetle the only chassis reinforcements, are the ones in the heater channels...
Old August 5th, 2003, 04:40 PM   #8
vwfye
this is actually a daily driver for me in the sunny months. and i am only missing the rear seat because of the midengine. you can do the roll cage and still have access to the rear seats. not really an issue either.
Early 64 Notch
73 Squareback
72 Kombi
75 Westy
vwfye is offline
Old August 5th, 2003, 06:27 PM   #9
type3rod
Vwfye,do you have some kind of top for your speedster??? It looks like there are some kind of klip things all aroung the top.
type3rod is offline
Old August 5th, 2003, 06:28 PM   #10
type3rod
pic
type3rod is offline
Old August 5th, 2003, 08:06 PM   #11
vwfye
they are for the english style tonneau cover. you can unzip just the driver's area and keep the rest of the interior dry.
Early 64 Notch
73 Squareback
72 Kombi
75 Westy
vwfye is offline
Old August 5th, 2003, 09:09 PM   #12
Looki here: :) more about this topic.
Cuttin' n strenghtenin'
Hebster52 is offline
Old August 6th, 2003, 06:36 AM   #13
type3rod
Thanks for all the info.Alot of help!
type3rod is offline
Old August 6th, 2003, 06:38 AM   #14
type3rod
Actually just thought of this.Should I add all the braces before cutting the roof off,so the shape stays?Or cut the roof then add the braces?
type3rod is offline
Old August 6th, 2003, 07:06 AM   #15
PapaG
PapaG's Avatar
Add the braces before cutting....
Dare to color outside the line. Think out of the box. Be the box. 69 Fastback, 69 Chopped top Squareback, 87 Syncro Vanagon, and more useless projects in the yard to make any redneck jealous.
PapaG is offline
Old August 6th, 2003, 10:41 AM   #16
vwfye
If you don't re-enforce the pan before you remove the top you will more than likely experience doors that don't quite shut right. also, when you remove the top, the rear pillar area has foam in it... so, be careful to avoid FIRE! [img]style_emoticons/<#EMO_DIR#>/unsure.gif[/img]
Early 64 Notch
73 Squareback
72 Kombi
75 Westy
vwfye is offline
Old August 6th, 2003, 12:47 PM   #17
type3rod
Thanks for all your help.Your speedster would look sweet flat black!!
type3rod is offline
Old August 6th, 2003, 01:48 PM   #18
All_talk
Not true... there is extra steel all over in the stock vertÖ extra bracing by the hood hinges, double walling under the dash, triple walling on the sides of the footwells, fillets and double walling around the inside of the door opening, box type cross brace under the back seat, bracing in the top corners of the engine compartment... and the big boxed rails under the heater channels. But the pan is just the same as the sedan. :P
Just for information sake :)
Gary
No matter how broke I am, I always seem to find two cents.
All_talk is offline
Old August 6th, 2003, 09:29 PM   #19
Originally posted by All_talk+Aug 6 2003, 11:48 PM--><div class='quotetop'>QUOTE(All_talk @ Aug 6 2003, 11:48 PM)</div><div class='quotemain'> <!--QuoteBegin-Mr. Electric Wizard@Aug 5 2003, 11:13 AM
the box steel runners sounds like the way to go then...† after all, on a vert beetle the only chassis reinforcements, are the ones in the heater channels...
Gary [/b][/quote]
Yes, your absolutely right. That is why I'm making all the different extras on my Hebster, and not just the ones under the heater channels. :)
Old August 7th, 2003, 05:33 AM   #20
Mr. Electric Wizard
alright you all, i'm sooooooo sorry to be spreading dis-information...
Ok, so just brace the shit out of it... :D :D :D
Old August 7th, 2003, 06:10 AM   #21
I'm confused on whether y'all are talking about a Beetle or a Type 3 ... [img]style_emoticons/<#EMO_DIR#>/wacko.gif[/img]
Anyway, here's a page that show the reinforcement areas for converting a bug sedan into a convertible.
Props to Jan Andersson (Bugfuel) for this page:
http://www.geocities.com/janbugger/vert.jpg
edit: well, crap ... I didn't think about that being a geosh*tties page that browns out after you look at it twice. :rolleyes:
I'll attach the pic here if it's ok. [img]style_emoticons/<#EMO_DIR#>/unsure.gif[/img] Hope it helps.
Scott H is offline
Old August 7th, 2003, 08:09 AM   #22
All_talk
No Prob Wiz, but now you are on my dis-information list and Iíll have to start checking all your posts. :D :D :D j/k
Iíve thought about taking pics of all the reinforced areas on my vert, but I should have done it before I finished it because the carpet covers a lot of it. Maybe if I pull the carpet for the repaint this winter Iíll do it then.
Gary
All_talk is offline
Old August 7th, 2003, 09:38 AM   #23
B-snap
great info guys..now I gotta go find another one (bug)..well actually 2 more... :D
Branden
2003 1.8T Jetta
1990 1.9L Corrado G 60
1968 1641 Baja
B-snap is offline
Old July 28th, 2004, 04:53 PM   #24
I found some decently detailed blueprints on how to make your own vert rails (measurments, where to drill, etc), you can download them here. They're in PDF format BTW.
Alternate link: http://www.pre67vw.co.uk/downloads/default.asp
Nick is offline
Old July 28th, 2004, 05:36 PM   #25
BOOOGHAR
cant you just do something like a 6 point cage ? I'd rather do that and cover it up with some old bamboo or palm tree leaves , go for some fantasy island looking shit
what has 2 thumbs and loves blow jobs ...... &quot; THIS GUY ! &quot;
BOOOGHAR is offline
