Threads: 32,379
Total Online: 869
Old June 12th, 2005, 04:58 PM   #1
Started installing my suicide hinges, fun part of the project [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img] So thought I'd start a thread. I'm usng ROcky Hinges hidden hinge kit, I got the deluxemedium kit ($300), somes with pre-alligned hinges (I highly recommend!!!) and bear claw latches and mouning kit. Comes with instructions
https://host258.ipowerweb.com/~rockyhin/cgi...duct=Hinge-Kits
What the pre-alligned hinges look like. Most people (even expereince folks) have a hard time installing suicide hinges because noth hinges has to be perfectly alligned. With pre-alligned kits like this, it will cut down your headaches and time tremendously.
Place hinges as close to the middle as possible, cut out the squares and test fit. Follow instructions as may vary depending on manufacture. My pin is located roughtly an inch from the outer edge of the pillar, need to trim the extra square tubing as fit
As the Beetle's B pillar is thing, it will need to be trimmed to fit the thick hinge posts. Hinges tacked for now until everything is certain it alligned properly.
Then I cut a slit on the door's inner post, inserted the hinges into it to test fit. That's it for now, I clamped the hinges into the door panel to test the swing, so far so good [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
Full swing, I'll limit this later on. It swings downwards because of the slanted pillars (FYI) so opens in a wierd angle
So far about 30 minutes of labor. To be continued.....
Nick is offline
Old June 12th, 2005, 05:18 PM   #2
Looks awesome Nick. Can't wait for the new pics. ....Tim
Turbo Punk is offline
Old June 12th, 2005, 05:35 PM   #3
reub-revhead
reub-revhead's Avatar
Looks great. I couldn't believe it when you started cutting up your bug but it's taking shape. Sweet!
Kinda wish I'd have installed hidden hinges....
Reub
~go the volksies~
reub-revhead is offline
Old June 12th, 2005, 05:35 PM   #4
georgiaboy
georgiaboy's Avatar
gonna be one badass ride nick...................... [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
Tricycle motor builder.
georgiaboy is offline
Old June 12th, 2005, 06:36 PM   #5
charlie408
sweet dude is that the stock dash or is it moded
I work for Honda and Civics are boring!
charlie408 is offline
Old June 12th, 2005, 06:54 PM   #6
75bugrod
nice man, now if only i had doors [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
75bugrod is offline
Old June 12th, 2005, 07:11 PM   #7
http://mywebpages.comcast.net/nicanor/runt-dash.html
dash is definitely not stock
It feels good having the hinges mocked up, for the 1st time I can open and close the door (even though they're only clamped on temporarily) but definitely a stepping stone I was looking forward to. I remember pissing off the anti-purists when I 1st started the project [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
http://volksrods.com/forums/index.php?act=ST&f=2&t=1775
Nick is offline
Old June 12th, 2005, 10:38 PM   #8
Wow! Lots of old names in that thread!
Lookin' good Nick!
ThrasherBill is offline
Old June 13th, 2005, 07:39 AM   #9
dayzwalker
dayzwalker's Avatar
Wow nick thats really looking great! What are you going to have to do about adding some bracing in/around the B pillar and in the rear quarter panel area to help support those bug hinges??? [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img]
I remember seeing some pics of hidden/suicide hinges in your photo gallery and the guy had added quite a bit of bracing in that rear quarterpanel area, but also made it so that no door pnael could go back in there. Is there a better way around that? Have you started to think about REAR interior options yet???
A Fetivus for the Rest-iv-us
dayzwalker is offline
Old June 13th, 2005, 08:27 AM   #10
I believe this one's from bugdust's project
For me, it won't be a problem as I can make a new custom inner panel in the back, but for a stock Beetle it maybe a ltitle more trickier. Hopefully bugduist will chime in to see what he's done for the rear panels. One option is to widen the B pillar to hide the hinges and start the panels further back. My car won't need as much bracing, my door's about half the weight as a stocker anyways. My new motto for the project: I'll deal with it when the time comes [img]style_emoticons/<#EMO_DIR#>/imwithstupid.gif[/img]
I'm leaving the rear end (window) for last as I'm sure it'll be the hardest to pull off (but will also be the most distinctive feature on the car). Hint: ever wondered why I have so many VW30 prototype pics in my gallery [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
Nick is offline
Old June 22nd, 2005, 05:46 PM   #11
Been fixing a bunch of stuff I messed up (rebuilt the bottom frame twice, etc). So I finally was able to get to the hinges once again. It's tacked onto the doors and opens and closes under it's own power fine (only took two tries) [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img]
Made a quick video clip (2.1mb). I forgot how low my car was until I watched this clip [img]style_emoticons/<#EMO_DIR#>/smilespin.gif[/img]
Suicide Doors <span style="font-size:8pt;line-height:100%">right click --> save as</span>
Nick is offline
Old June 22nd, 2005, 05:50 PM   #12
PAPA_SMURF
PAPA_SMURF's Avatar
sweet dude [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
...Joey
66 schwinn, 04 Jetta
vwclubofhawaii.ning.com
PAPA_SMURF is offline
Old June 22nd, 2005, 06:09 PM   #13
swoodard23
swoodard23's Avatar
I really like it. It looks pretty mean. Can't wait to see what you do next.
Scitt
swoodard23 is offline
Old June 22nd, 2005, 06:10 PM   #14
Awesome, Nick!! [img]style_emoticons/<#EMO_DIR#>/bowdown.gif[/img]
I checked out that old post... it was hilarious reading everyone's reactions when you first cut that thing up [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
I even found a new signature... [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
Looks really nice man. Like the decal placement too [img]style_emoticons/<#EMO_DIR#>/smokin.gif[/img]
Steve is offline
Old June 22nd, 2005, 07:14 PM   #15
Flipper_1938
Flipper_1938's Avatar
What is the over all height of that thing as it is now?
Flipper_1938 is offline
Old June 22nd, 2005, 07:44 PM   #16
I'm guessing about 47" +/- at the highest roof point. I'm about 5' 7", it goes about a few inches above my belly button right now. I'll measure it next time I go there for a definite answer.
Nick is offline
Old June 23rd, 2005, 01:03 AM   #17
grumpy
Mr. Asshole Moderator
grumpy's Avatar
rock on brutha. all you need is some velcro, screw the door latch [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img] it would be funny as hell to get out and hear the sound of the hook and loop pulling apart.
grumpy is offline
Old June 23rd, 2005, 03:13 AM   #18
Flipper_1938
Not with SUICIDE doors! ! ! !
He needs some VERY POSITIVE LATCHING LATCHES
Old June 23rd, 2005, 11:14 AM   #19
Kwantum
[img]style_emoticons/<#EMO_DIR#>/imwithstupid.gif[/img] Jay Oh Kay E [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
<span style=\'font-family:Impact\'><span style=\'font-size:16pt;line-height:100%\'><span style=\'color:red\'>-KWANTUM</span></span></span>
Kwantum is offline
Old June 23rd, 2005, 11:24 AM   #20
grumpy
grumpy's Avatar
Originally posted by Flipper_1938+Jun 23 2005, 05:13 AM--><div class='quotetop'>QUOTE(Flipper_1938 @ Jun 23 2005, 05:13 AM)</div><div class='quotemain'><!--QuoteBegin-grumpy@Jun 23 2005, 01:03 AM
[/b][/quote]
it was a joke [img]style_emoticons/<#EMO_DIR#>/rollingeyes.gif[/img]
grumpy is offline
Old June 23rd, 2005, 12:50 PM   #21
57Drag
57Drag's Avatar
My dad want's me to install my passenger side hidden hinges on the front of the door.Nice progress Nick,looks great......Donald
57Drag is offline
Old June 23rd, 2005, 04:53 PM   #22
Don't do it Donald, that just looks wierd when the doors are different from each other.
Nice job Nick. Have you done this before.
I can think of a few things I would do diferently now that I have done mine.
Jon is offline
Old June 23rd, 2005, 05:55 PM   #23
This is the 1st time I'm doing hinges. I doubt anyone would want to follow exactly how I'm doing mine. My project isn't really your standard job in doing these hinges, but still a good reference either way [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img]
A little more progress, picts of the hinges with the "hinge pockets", screwed the hinges onto these door pockets then welded the pockets onto the doors. Hinge pockets still needs to be trimmed to fit
I welded a square tubing between the pockets to keep doors from flexing (bottom hinge may open further then top hinge causing the door to wobble, etc).
Kit comes with pre-fab latch plates
Trimmed and tacked into place
Doors now closes and locks [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img] Now pretty much all is left is take the doors off and finish the welds.
On a side note, forgot who was thinking about the idea of just swapping the post skin around to make suicide doors. After doing this I think that would be 3x harder. If you get normal hinge kit or similar, you can tack weld the door shut before cutting off the stock gines/latches. Then weld the new hinges into place, this way the doors will remain alligned. If you swap the posts around, there is no way you can do this. You'll have to swap 4 skins around (both pillar posts and both side of the doors to match). Plus keeping them perfectly alligned will be hard because you can't place reskin the posts anymore while the doors are tacked. WIll be just trial and error, tack and refit and hope for the best, cut the tack and retack, etc etc... Anywass just my input on that method. Plus the door posts are sometimes dual skinned and in places where the hinges are located is usually have alot of heavy plating behind it that will be tricky cutting out and able to reuse them.
Nick is offline
Old July 2nd, 2005, 06:05 PM   #24
Progress done in honor of Pete's recovery.
Latch pin ready for final body work
Latch stike plate ready for final body work
Door hinge area ready for final body work
All is left is the door pocket (on the door's area), need to cover the hinges, finish the panel area and that's it
I decided to put a square tubing on the hinges to the latch area to help stablize the hinges, though not really needed on a stock door IMO, but on my doors there's not much inner door panel left to weld the door pockets onto. And no, these aren't meant for an impact crash bar.
Nick is offline
Old July 2nd, 2005, 06:47 PM   #25
Flipper_1938
Have you thought about adding REAL door bars? The thought has crossed my mind a time or two.
I think, the trick would be beefing up the ends of the door and door jambs to be strong enough to "hang on to" the door bar.
