Threads: 32,385
Total Online: 542
Old July 2nd, 2007, 03:51 PM   #1
onelowzuki
Default Has anyone ever made their own drop axle?
Looking at doing a drop axle and was courious if anyone has ever made their own from scratch? , I was thinking of doing it Due to the fact what I want is not available commercially.
onelowzuki is offline   Reply With Quote
Old July 2nd, 2007, 03:55 PM   #2
bswilly
bswilly's Avatar
Default Re: Has anyone ever made their own drop axle?
I've seen alot of home made A arm stuff.After seeing a speedway kit in person if you had the time to get it straight I don't see why not
1965 hard top...under heavy construction
1971 super vert/roadster...daily driver
2002 GTI...new car
www.ccvw.org <----my local club
http://images.dr3vil.com//files3/9/d...ns-animate.gif
bswilly is offline   Reply With Quote
Old July 2nd, 2007, 04:09 PM   #3
You want to "drop" a I-beam axle ?
Or make your own tube axle ?
Old July 2nd, 2007, 04:12 PM   #4
onelowzuki
Make my own tube axle
Old July 2nd, 2007, 04:27 PM   #5
Not that hard,but your welding needs to be 100%.
A lot of the streetrod places will do custom order tube axles.
They have the material,experience,and equipment,to do it right the first time.
Just don't deal with MAS.
Old July 2nd, 2007, 04:33 PM   #6
onelowzuki
Welding being 100% is definatly taken care of, I am more interested in tubing types and thickness, any general pointers, how much caster I should have etc.
Old July 2nd, 2007, 05:42 PM   #7
6-10 degrees of Caster,king pin inclination
will depend on the spindes you use.
The bosses for the perch bolts are usually
the same angle as the king pin bosses.
Or you could weld Batwings on.
Then you have to figure out how to bend the tube.
Check the streetrod sites,to see what people advertise
their axles being made from.
Old July 2nd, 2007, 05:49 PM   #8
gowjobs
gowjobs's Avatar
Didn't somebody use the spindles and those pieces that hold them from a king/link front end to build a drop axle of their own? Cool idea - keeps it all VW, matching lug patterns, etc.
-Dave
"When worse comes to worst...
..we're screwed"
gowjobs is offline   Reply With Quote
Old July 2nd, 2007, 06:10 PM   #9
speed
speed's Avatar
the cost to get set up to build a good dropped axle, and the learning curve to have confidence in the end result will cost you more than buying one.
You can do it, but it aint easy, and it aint cheap.
Buy heck, go ahead---you might be the next Axle Bid Dog!
Just say NO to SLOW!!!!
speed is offline   Reply With Quote
Old July 2nd, 2007, 09:45 PM   #10
Check Hotvw's threads. He have made two from scratch. He doesn't have many photo's but you get the picture so to speak..
Old July 2nd, 2007, 10:44 PM   #11
Have you ahd trouble with MAS before, Uncle Ian?
Old July 3rd, 2007, 04:57 AM   #12
This ones is from Hotvw, I believe.
This one is from Curtstom
There used to be a guy on ebay that sold plans, I didn't find him just now however. Here is a link to a lot of info that may help.
Roadsters Dropped axles
Old July 3rd, 2007, 05:12 AM   #13
Sorry mkparker but both those are the same made by Hotvw..
This is Curtstom's:
Old July 3rd, 2007, 08:19 AM   #14
Their name has come up on the HAMB several times.
Some people only research a company AFTER they spend
their money,not before.
Old July 3rd, 2007, 02:16 PM   #15
Thanks for the correction Hebster!
Old July 4th, 2007, 03:29 PM   #16
SHARK
Speedway Motors also sells the kingpin bosses for 28-48 Ford spindles so that you can fab your own axle without machining the bosses. They exsist for sprint cars and early diggers with custom suspensions.
They have a step that slips into the axle tube where you weld them on for alignment. If you can build a jig to index them vertically you're set....
SHARK is offline   Reply With Quote
Old July 4th, 2007, 04:11 PM   #17
Hotrodpez
Hotrodpez's Avatar
Location: Mission Viejo, Orange County, Kalifornia, USA, Earth, Sol System, Milky Way.
Ahem... Rat Patrol front axle anyone?
- Luke
__________________________________________
Originally Posted by bugdust
If you can't measure your own floor then this project may be too much for you...just my opinion.
People who say im hard to shop for must not know where to buy beer...
Common parking lot conversation...
Its a volksrod...
Yes, it runs...
Yeah I drive it...
No, I'm not crazy.
Here's to living single, seeing double, and sleeping triple!
Myspace: http://www.myspace.com/lukepezanoski
Hotrodpez is offline   Reply With Quote
Old July 4th, 2007, 05:09 PM   #18
Nope, store bought! The mounting brackets and mounts were all Walt made!
Old July 4th, 2007, 06:27 PM   #19
blacktruck
blacktruck's Avatar
http://volksrods.com/forum/showthread.php?t=4839
we can't leave duneadx outta this discussion
nut up or shut up
Old December 4th, 2014, 08:20 PM   #20
Found this, about spindles:
https://tbucketeers.com/threads/non-...s-for-gb.6223/
Old December 8th, 2014, 11:53 AM   #21
Holy mother of 7 year old posts batman!
I was working on a trailer axle for a small trailer for a my FireAero. going to mount a cartop carrier on a small frame using ball joint spindles bearings, etc. the Fire Aero uses a Bj front end and a VW rim for the rear so I want a common wheel tire for everything. it's all cut and mocked up but I just ran out of free time and motivation to get the axle to a certified welder.
Old December 8th, 2014, 12:26 PM   #22
"I'm not into time."
Indian Larry
