Threads: 32,385
Total Online: 574
Old November 5th, 2010, 02:05 PM   #51
Default Re: Tube pan
So is it all loaded up and ready to go? Is it done yet? No?
so wtf is the hold up? gitrdun!
yes, I'm a pest
Old November 5th, 2010, 02:40 PM   #52
BEERcobra
BEERcobra's Avatar
Yes MOM I'm all packed.. I brushed my teeth too
Old November 5th, 2010, 02:45 PM   #53
good boy!
Now,
is it done yet?
Old November 5th, 2010, 03:38 PM   #54
Jogyver
Jogyver's Avatar
That stuff in the back of the truck looks too much like work.
Old November 5th, 2010, 03:42 PM   #55
BEERcobra
BEERcobra's Avatar
If your insurance is all payed then you could just sit back and let me go at it with your tools
Old November 5th, 2010, 04:05 PM   #56
Jogyver
Jogyver's Avatar
If you get hurt .... I'll just bury you out back .
Old November 5th, 2010, 04:39 PM   #57
If you do, I call dibs on all the car stuff!!!
Old November 5th, 2010, 04:51 PM   #58
can i get the pan?
Old November 5th, 2010, 04:56 PM   #59
BEERcobra
BEERcobra's Avatar
You guys are acting more like family then friends.
Old November 5th, 2010, 05:04 PM   #60
Can I have all that metal stock? I need a BIG deer stand!
Old November 5th, 2010, 05:13 PM   #61
BEERcobra
BEERcobra's Avatar
Old November 5th, 2010, 05:14 PM   #62
Sorry guys, I got dibs on the metal!
Old November 5th, 2010, 05:26 PM   #63
BEERcobra
BEERcobra's Avatar
The only steel your getting is my steel toe work boot in the nuts.
Old November 5th, 2010, 06:24 PM   #64
Tease...
Old November 5th, 2010, 07:56 PM   #65
Jogyver
Jogyver's Avatar
BeerCobra...... Remember my family history. Public enemy No. 9
Old November 6th, 2010, 09:47 AM   #66
BEERcobra
BEERcobra's Avatar
Wwwwhhheeeeeeeee
Old November 6th, 2010, 10:13 AM   #67
Originally Posted by Desert Fox View Post
3.8 ford is lighter than the gm equivalent and the 3.8 is based off of the 302. Due to the aluminum heads and the early models had a motorcraft 2bbl. Do remember that the 302 is a great motor in stock or mild form. I have a mild comp cam and gt-40y heads and intake on mine in my ranger. The motor makes gobbs of horsepower at high rpms, but the bottem end suffers. But that should not matter in a car that weighs half of what my truck weighs.
What would be tits would be build a 302 with 4-v Cleveland heads, and get a boss intake. Instant 300 hp but still you'd have to turn the piss out of it to realize those #s
Oh and thats some good loking work you've done.
Ummmm.... That information is not entirely correct...
Ford wanted a good V-6, but didn't have a platform to start from. So they did it the American way. They took a GM 3.8 and reverse engineered it. They solved all the stress issues and got a sturdy, reliable V-6 that had a good blend of torque and Hp. It just happens to be the equivalent of a 302 - 2 cylinders, but that is only coincidence. They later stroked it into the 4.2 that was available in all the '97-'04 (Heritage) F-150's.
And yes, the early Ford 3.8 was carbed, however the intake from those engines will not fit the post '97 heads you are referring to. The actual best combination is to take a 4.2, use the intake (minus the plenum) from a '95 Windstar, build an adapter to run three Solex 30's, and you have to run the timing cover from the 80's Granada (for the dizzy) to totally do away with the PCM. You can then replace the ford DurraSpark Ignition box (a.k.a. brain) and run the Mallory V-6 distributor and ignition box. Then add factory '95 Mustang shorty headers into a 3" "X" pipe scavenging exhaust system. This will get you into the low 400 Hp range...
It's been done. Just sayin...
Old November 6th, 2010, 10:24 AM   #68
Thx, I have looked into the ford 3.8 because I love the idea of aluminum heads. I'm still looking into that motor for aftermarket parts.
Distributor,intake for carb are the major parts needed.
As soon as I have the body and trans installed il know what look I like v6 or v8 then il pick the engine.
If you're really entertaining the idea of the Ford 3.8, let me know. I know of some pushing out 600 Hp. I know, it doesn't sound possible to get 100 Hp per cylinder out of an American "utilitarian" engine, but it's true. There is an all aluminum version also, but I couldn't begin to tell you where to start looking. They also make two and four BBL carb'ed intakes to fit the post '97 engines. I keep referring to the post '97 engine because that was the last and best one in production. The earlier ones ('90-'96) had head gasket issues. It was like clockwork, every 80,000 miles you would blow a head gasket at #1 or #4 cylinder. They worked on the problem and stretched the range out to 120,000 miles, before they finally redesigned both the heads and block to accept a layered head gasket. The ending result yielded over 250,000 miles without issue.
By the way, I've been a Ford Master Tech since '99...
Old November 6th, 2010, 10:28 AM   #69
On second thought, please don't run the Ford 3.8. I'm tired of giving away all my tips only to be later accused of copying the very same people I assisted to begin with.
Old November 6th, 2010, 02:25 PM   #70
BEERcobra
BEERcobra's Avatar
Wow!!! Killer info! thanks
Well jogyver and I worked our fingers to the bone today!!!
Oyea!!!!!!
Old November 6th, 2010, 02:57 PM   #71
Paul and Joe are &^%#$%$#@!!!! sick!!!!!!
Old November 6th, 2010, 03:00 PM   #72
Too cool
Old November 6th, 2010, 03:11 PM   #73
Desert Fox
Desert Fox's Avatar
I was summating what I knew abought the ford 3.8. Yes I've replaced many a head gasket on them manily because some one drove the car they were driving through the ditch and tore the air dam off of it and ran the car hot, but they have a habit of blowing on there own. If I were going to run one I would stroke it to a 4.2 and run the fuel injection. Possibly the megasquirt kit, just because I want to build one. I also thought of adapting one to the tranny in Ilsa because I feal that the weight diference is acceptable for the power gains.
Hay Cobra build it your way, sorry for the hijack. Your work looks realy good. Also a 215 Buick v-8 aledgedly weighs 209# good luck finding one Since they were built from61-63 and came in the Special and the Skylark. It is a populsr swap for mg owners. It is also suposed to be the same motor used in the land rover but dont Quote me on that.
People with bolt on mods have comitment issues.
Desert Fox is offline   Reply With Quote
Old November 6th, 2010, 06:06 PM   #74
No "bones" about it.....looking good guy's!
I still can't believe you cut up a "67".
Old November 6th, 2010, 06:37 PM   #75
tirezan
tirezan's Avatar
Man that is some nice work.But you guys have gotta stop and eat. You look starved to death.
