Threads: 32,385
Total Online: 498
Old October 29th, 2011, 12:35 PM   #1
Default My English Wheel
Exploded view of quick release and lower yoke.
Old October 29th, 2011, 12:36 PM   #2
Default Re: My English Wheel
Quick release, in lowered position.
Old October 29th, 2011, 12:37 PM   #3
As the cam turns,it lifts the lower yoke.
Old October 29th, 2011, 12:37 PM   #4
Rotary cam in UP position.
Old October 29th, 2011, 12:39 PM   #5
Yoke is attached by a single 1/4"-20 screw.
(Lower yoke removed for clarity)
Rotating the cam counter clockwise raises the yoke.
The same direction as the foot adjuster.
Convenient and easy to remember.
Cross pin is 3/8" diameter, cam gives about 5/16" travel.
Plenty of room to swap lower anvils.
Inner shaft is 1.250 diameter., main shaft is 1.750 diameter.
Old October 29th, 2011, 12:39 PM   #6
ID was bored to 1.130 after welding.
Old October 29th, 2011, 12:41 PM   #7
Handles are 3/8" dia, about 4" long. Bent to suit.
I would use 4 handles next time.Or connect the ends of the handles together, with a large ring.
Old October 29th, 2011, 12:43 PM   #8
Old October 29th, 2011, 12:44 PM   #9
Old October 29th, 2011, 12:49 PM   #10
Shaft is 1 3/4" OD Hard Chrome shaft. Top of shaft is bored 1.255" ID.
Frame is 2 5/8 DOM,bored to 1.755" ID 3/16" split pins riding in 3/16"
wide slots stop any rotation.Shafts will slide up and down,without any wobble.
Hard Chrome is definitely not necessary, but the price was right.
Old October 29th, 2011, 12:52 PM   #11
Upper and lower columns. A pair of 3/16" key ways,
and matching split pins, prevent any rotation.
I used split pins, because they don't rely on an accurate press fit.
Old October 29th, 2011, 12:55 PM   #12
Upper and lower column, with yoke. Exploded view.
Large shaft is 1 3/4" ,small diameter is 1 1/4". I used hard chrome shaft because
it was free. Precision ground shaft or mild steel would be fine. 3/16" wide slots,
in each piece,accept a 3/16" split pin to stop rotation. A 3/8" dowel pressed through the smaller shaft, accommodates the quick release cam. A 1/4-20 thread in the upper end allows the lower yoke to be attached. The orientation of the lower wheel can be changed by loosening the screw, rotating the yoke to the desired position and tightening the screw.
Old October 29th, 2011, 12:56 PM   #13
Lower yoke detail,assembled.
Old November 6th, 2011, 07:29 PM   #14
A pair of 10-24 flathead cap screws.
Old November 6th, 2011, 07:30 PM   #15
Disassembled.
Old November 6th, 2011, 07:33 PM   #16
Verticals are 1/4" thick. Horizontal is 1"x2"x3 1/4" A pair of 10-24 flathead screws
hold each of the vertical plates in place. Counterbored 1/4"-20 cap screw in the
middle attaches the yoke to the column.
Old November 6th, 2011, 07:33 PM   #17
End plate.
Old November 6th, 2011, 07:36 PM   #18
The mild steel axles are 1/2" dia at ends, 3/4" dia in center. Bearing diameters
need to be concentric. At assembly,the axles are captured between the bearings.
The upper axles are slightly longer,with a #7 hole near each end for the screws,
to attach to the upper yoke.
Old November 6th, 2011, 07:38 PM   #19
Rough machined on left, bearing diameters finished on right. 3" finished OD
must be concentric with bearings. Bearings are 6202,same used in upper wheel.
Easy to get and not expensive. I got double sealed bearings,shielded bearings
would turn easier.
Old November 6th, 2011, 07:41 PM   #20
Each anvil wheel gets it's own axle.
Axles are captured between the press fit bearings.
That way the axles don't fall on the floor when you are changing wheels. Lower wheels 3" dia x 3" wide.
Old November 6th, 2011, 07:42 PM   #21
Each lower roller gets stamped on both ends
with a number which indicates the radius.
The extra small hole is to drive the piece when
turning the radius between centers.
Old November 6th, 2011, 07:43 PM   #22
Lower anvils assembled. From top left:
Flat,10",6",4",2.5" radi.
The flat anvil has 2 different corner rads, for tipping flanges.
The od on all lower anvils is the same.
Old November 6th, 2011, 07:45 PM   #23
Left is 6" OD,3" wide polished steel.
Right is a 6" OD Urethane caster, 2" wide.
The upper wheel wants to be at least double
the OD of the lower wheels.
Old November 6th, 2011, 07:46 PM   #24
Upper axles are drilled through and spot faced for 10-24 cap screws.
Old November 6th, 2011, 07:47 PM   #25
A single 10-24 cap screw on each side holds the axle in the Yoke.
