Threads: 32,384
Total Online: 527
Old February 11th, 2014, 11:59 AM   #1
Loren in MN
Loren in MN's Avatar
Default Anyone mounted sidepipes on a Beetle?
Has anyone mounted sidepipes like those used on a front engined vehicle to a Beetle and have them actually functional? or just fake?
I've been trying to find any picts showing a view of pipes mounted. Not looking for pipes that ONLY stick out in front of rear wheels, but pipes similar to those mounted on a Vette or Chevelle.
Thanks for any help,
Loren
Loren in MN is offline   Reply With Quote
Old February 11th, 2014, 12:40 PM   #2
Default Re: Anyone mounted sidepipes on a Beetle?
Just google VW sidepipes. There are some videos out there. Also a numper of folks have done it, just don't know exactly where to point you for pictures.
Old February 11th, 2014, 01:31 PM   #3
now, I don't know much about exhaust pressure and whatnot, but it just seems like the biggest problem you are going to have in making them function with a rear engined car is that if i understand what you want properly, you want your pipes to exit the engine, go basically the full length of the car up to the front, and then go most of the way back to exit.. that's a LOT of exhaust piping.. just seems like a complete waste and would care very little pressure, might even encourage exhaust gases to build up and not exit properly..
but again, I don't know shit about shit, that's just my hypothesis..
Old February 11th, 2014, 01:46 PM   #4
Or, you can do like with my Alfa kit car. Full pipe down the side, but actual exhaust tied in right at the end of the run so it exhaused out the side pipe.
Old February 11th, 2014, 02:10 PM   #5
Buy these and do what Alykat Said... Just "merge them" at the back end of the pipe but hang something pretty alongside the body of the vehicle... It would work, I just don't see the need in a long pipe. I do like the G-Down ehaust though.
http://www.gdownusa.com/
Old February 11th, 2014, 02:11 PM   #6
Run a set of side pipes then just do what was done above like reverse baja pipes if that makes sense. Will require some fan work but it'd be worth it. Hell I wonder if you could mount it in that edge the running boards go into.
Sent from my Z665C using Tapatalk
Old February 11th, 2014, 03:12 PM   #7
drscope
drscope's Avatar
J.C. Whitney used to sell a side pipes kit for the Beetle years ago. And they were functional!
drscope is offline   Reply With Quote
Old February 11th, 2014, 05:28 PM   #8
I remember those. I always thought it was kinda cheesy, to put fake stuff on a car.
Why would you wanna run pipes up to the front ? I dont get it, just like those Gdown pipes don't make any sense , but maybe its just me.
Old February 11th, 2014, 05:31 PM   #9
hotsauce
hotsauce's Avatar
I'm building a dual side exit exhaust... I'll post pics when I get a little further.
www.garagejunkieapparel.com
hotsauce is offline   Reply With Quote
Old February 12th, 2014, 02:23 PM   #10
nhtriker
nhtriker's Avatar
I thought we had a vender on here that sold a system to make the exhaust exit ahead of the rear wheel. That'll get ya half way there!
nhtriker is offline   Reply With Quote
Old February 12th, 2014, 02:31 PM   #11
G-down like was posted up top.
Old February 14th, 2014, 05:07 PM   #12
just mount 'em backwards so the outlet is just behind the front wheels
Old March 21st, 2014, 07:53 AM   #13
dero
Yeah the way I was going to go was g down pipes and have it exit at the rear of the side pipes ( in Australia we call them leg burners ).
dero is offline   Reply With Quote
Old March 21st, 2014, 10:50 AM   #14
volkswagnut
volkswagnut's Avatar
I considered going to go the reversed "lake pipe" route on my Operation X...
And I mean fully reversed with the outlet up front...
I stopped at the the quarter panel... but left it where I could always add on if I changed my mind...
but right now....
Decided not to yet...= More weight.. more heat.. and extreme noise in both ears...... Its bad enough with them exiting in front of the rear tires..
But .. its different and
You get to smell the sweet smell of real exhaust while driving.. or idling...
Not to mention piss off every bank teller and drive through window operator...
Plus those in traffic... those are the best.
If you have a swing axle.. take into consideration travel.. I routed mine under... I ALWAYS have to lock the spring plate up before raising the rear off the ground..
Built to drive not decorate
It's all about the going not the showing
volkswagnut is offline   Reply With Quote
Old March 27th, 2014, 07:46 AM   #15
bugboy2110
bugboy2110's Avatar
i have a vandetta with functional side pipes on it i can get you pics of it when i get home
bugboy2110 is offline   Reply With Quote
Old January 4th, 2015, 11:07 AM   #16
Loren in MN
Would love to see your pics! Thanks,
