Threads: 32,385
Total Online: 509
Old November 26th, 2014, 09:29 AM   #1
Thunderbird Jay
Default Radius Rod/Wishbone Mounting
Hi all,
Been a while since iv been on here and seems plenty busy!
down to business,
Now we've all seen the same pictures of the infamous Stinkbug (i know, i know)
However its this one I'm particularly interested in:
Has anyone ever seen the car up close and is able to describe the mounting method for the pivot end of the split bone?
Its obviously inside the front quarter panel/footwell but im curious to see exactly how it was done? I like the idea of it passing through a 'boot' and could give the opportunity for keeping some much needed length to the wishbone.
Many Thanks
J
Thunderbird Jay is offline   Reply With Quote
Old November 26th, 2014, 10:10 AM   #2
Default Re: Radius Rod/Wishbone Mounting
I wouldn't copy the design exactly:
http://socalook.com/whatissocal/look3.html
Old November 26th, 2014, 10:12 AM   #3
https://web.archive.org/web/20040827...s/image4.shtml
Old November 26th, 2014, 10:13 AM   #4
https://web.archive.org/web/20040621...cs/hairpin.jpg
Old November 26th, 2014, 10:14 AM   #5
Thunderbird Jay
Naaaaaahhh that cant be whats used!
that bracket would be right where your legs need to be in the footwells if it entered through the body where it does?
Old November 26th, 2014, 10:16 AM   #6
Thunderbird Jay
ewwww thats awful
back to the drawing board
Old November 26th, 2014, 10:18 AM   #7
Thunderbird Jay
i still cant see how that would work on the pic i posted, i can see it on other socal kit equipped volksrods but the pivot looks to be much further inside the car on Stinkbug
Old November 26th, 2014, 10:21 AM   #8
Walt had a much better design , here: http://volksrods.com/forum/showthrea...t=18711&page=2
Old November 26th, 2014, 10:24 AM   #9
Speedway modified the original design,
and made it shittier. I mean cheaper.
http://www.volksrods.com/forum/showthread.php?t=10694
Old November 26th, 2014, 10:28 AM   #10
Thunderbird Jay
stronger, yes
prettier, no
Anyone else seen the mounting method on the later split bone fitted incarnation of SB?
Old November 26th, 2014, 10:31 AM   #11
This is horrible:
Old November 26th, 2014, 10:32 AM   #12
Old November 26th, 2014, 10:44 AM   #13
Thunderbird Jay
christ that single shear nastiness is just plain bad engineering.
Thanks for the effort Unkl Ian! appreciated
Old November 26th, 2014, 10:46 AM   #14
Speedway and bad engineering,
go together, hand in hand.
Anytime, glad I could help.
Old November 26th, 2014, 02:28 PM   #15
To be honest a lot of that looks fuugly and triggers my primal danger sense.....I think an extended beam would be better at that point especially with how crappy the I beams seem to be.
Old November 27th, 2014, 01:39 AM   #16
Thunderbird Jay
nah, been there done that
I want to take the car to the next level and I can make it work.
Just wondered how they did it on the later set up on Stinkbug as it looks pretty slick.
cheers
J
Old December 3rd, 2014, 01:47 PM   #17
cheers
J
The set up on the Stink Bug was long before the Socallook front end.
Probably the easiest way to recreate it is to take a split wishbone front end, drill two big holes in the bug wheel wells, slide the two parts together and build a crossmember to attach the wishbones to.
Old December 3rd, 2014, 04:07 PM   #18
I remember reading, the Socalook parts,
were copied from the Stinkbug.
Old December 3rd, 2014, 04:08 PM   #19
If i was going to do a solid front axle,
on a Bug, I would probably use 1/4 elliptic springs.
Old December 3rd, 2014, 05:55 PM   #20
Quarter elliptical springs are ( IMHO ) the ONLY way to go on a volksrod. Add in triangulated top bars and it can't be beat in the departments of safety, handling, and looks.
But my opinion is bias.
Old December 3rd, 2014, 06:30 PM   #21
One of my favorite examples:
Old December 3rd, 2014, 06:32 PM   #22
Other examples, using friction shocks as upper links:
Old December 3rd, 2014, 06:40 PM   #23
Old December 3rd, 2014, 06:47 PM   #24
Old December 3rd, 2014, 06:57 PM   #25
