Threads: 32,380
Total Online: 910
Old April 8th, 2005, 12:09 AM   #1
oldschoolvette
Hey i was just wondering what are some common swaps for a type 3 squareback that will give you more power and also fuel injection if possible?
oldschoolvette is offline   Reply With Quote
Old April 8th, 2005, 03:36 AM   #2
Hey i was just wondering....who are you? [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img]
Old April 8th, 2005, 04:33 AM   #3
Tbone16
Yah man, just FYI, post an intro or your going to get dumped on. The best way to confront an issue like this is to resort to the search function. There you will find many existing threads about motor swaps. For a type three, I would think there would be some clearance issues. Other than that Kenneddy (clutch company) makes adapters for almost any motor to bolt up to a volkswagen tranny. However, naturally this is a bitch because you have to run wiring and often radiotors. Check out rueb revheads EJ20 beetle and you can see how much fabrication somthing like this takes.
Tbone16 is offline   Reply With Quote
Old April 8th, 2005, 11:09 AM   #4
vwcalbug
vwcalbug's Avatar
that later versions of type 3's actually had fuel injections.....how well they worked, thats debatable....there are a few resident type 3 guru's here, after you stop being such a noob and POST AN INTRO, and post pictures in GNF, and do a search, and read the "too lazy to search" thread....
READ THIS!! WORD FOR WORD, DO NOT JUST SKIM IT, LIKE YOU DID WHEN YOU MADE YOUR ACCOUNT HERE
http://volksrods.com/forums/index.php?act=boardrules
-JustinD
Its not Buy, Bitch, Drive
Its Cut, Weld, Drive!!!
vwcalbug is offline   Reply With Quote
Old April 8th, 2005, 02:20 PM   #5
cdubvdub
ive been told by everyone when i was looking for a square to stay away from fuel injected ones. Apparently theres alot of problems with the electrical or something
follow my instagram @cdubvw
Old April 9th, 2005, 11:28 AM   #6
PapaG
PapaG's Avatar
Mostly the FI is very good, till you get some who doesn't know about it jacking with it.. I loved my 71 square with FI...That said sometimes they are just fouled up you have to switch to carbs.
A Porsche 914 engine is a good swap. Subbie, some guys across the pound have used Alfa boxer engines. We have a member with a mid engined V8 olds in his too.
PS intro Please. [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img]
Richard
Dare to color outside the line. Think out of the box. Be the box. 69 Fastback, 69 Chopped top Squareback, 87 Syncro Vanagon, and more useless projects in the yard to make any redneck jealous.
PapaG is offline   Reply With Quote
Old April 9th, 2005, 11:55 AM   #7
dayzwalker
dayzwalker's Avatar
...as opposed to a Type 1 squareback? [img]style_emoticons/<#EMO_DIR#>/rollingeyes.gif[/img] .
hhhhmmm more power huh [img]style_emoticons/<#EMO_DIR#>/confused.gif[/img] ...how bout more displacement, bigger carbs, lumpy cam, ratio rockers and a midget driver!
Now you got some speed!!! [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
A Fetivus for the Rest-iv-us
dayzwalker is offline   Reply With Quote
Old April 9th, 2005, 12:11 PM   #8
FONZY
FONZY's Avatar
I hear that NoS is easy....
Or drive downhill alot....
Use a parasail?
Flintstone footwells?:)
pay someone with a faster car to push you around?
common swaps ...
old 6cylinder corvair engines
late 70's subaru (not sure model) flat four water cooled engines
60's-80's porche motors
Or go junk yarding with a tape measure and see what late model honda/ford/chevy etc subcompacts have somethign that might fit...
east Fuel injection, lotsa valves, decent displacement.. and usually alot of aftermarket 'tuner' stuff available.
use yer imagination n stuff:)
