Threads: 32,379
Total Online: 750
Old April 9th, 2005, 05:13 AM   #1
I've been messing around with some odds and ends fab stuff lately. I've made a bench seat for my bug, fitted and installed a '78 bus shifter, but the last few days I have been working on the hardest, but coolest thing yet. I was looking over the links on the home page and said "fuck I can do that". So last night I finished work on my 14" english wheel. And yes it works. I didn't fallow the plans exactly, but I have a wheel that gets the job done. I used a hub and bearing from an '02 Explorer. I pressed the bearing off the hub, pressed the studs out, then machined off the "drive flange". I then turned the shaft down to remove the press fit just incase I ever nee to replace the upper wheel. I then cut a groove for a snap ring the retain the wheel. For the bottom roller, I used a rear wheel bearing from an '00 Focus. I had to make a yoke to fit, then welded it to a steering shaft from a '98 C1500. I then ran a bolt through the bottom to adjust tension and welded a 17mm wrench to it for the handle. I tested it and had to make a few adjustments, but all in all I am pleased. Total cost...FREEBEE!! All parts and material were setting around the shop. I plan on grinding welds and painting today. Then I will be making corners for the p/u. So yes I went to the shop and made something [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img]
Old April 9th, 2005, 06:30 AM   #2
yumyumchoppers
yumyumchoppers's Avatar
PICS!!!!
yumyumchoppers is offline   Reply With Quote
Old April 9th, 2005, 07:26 AM   #3
Tbone16
Awsome, thats realy great to hear. You going to be taking some compound bend reaquests? Some preforated steel in place of my ghia grills would look nice.....JK man, good work.
Tbone16 is offline   Reply With Quote
Old April 9th, 2005, 08:06 AM   #4
pics will be up after I get it painted. As for farming out work? I thing that I need a bit more skill befor that. I'm just happy that I built something that works for a change. I go through a whole lot of trial and error befor I get some thing right, but this time I got it right the first time. You guys must be rubbing off on me or something.
Old April 9th, 2005, 11:35 AM   #5
carcentric
Grateful Member #484
carcentric's Avatar
Originally posted by Ray-Dean@Apr 9 2005, 08:06 AM
. . . You guys must be rubbing off on me or something.
MJ calls that "The Neverland Experience."
M D "Doc" Nugent
Old April 10th, 2005, 01:12 AM   #6
thrillcrazyspeed
thrillcrazyspeed's Avatar
Trial and Error? that's the name we gave my friend's bus....
Good show on the english wheel.
myspace: http://www.myspace.com/thrillcrazyspeed
I'm closing out VW parts galore, let me know what you need most...if you end up in the Greeley, CO area email me, you can come browse our warehouse.
Wear Blue Pants!!!
thrillcrazyspeed is offline   Reply With Quote
Old April 10th, 2005, 08:12 AM   #7
Tbone16
[/quote]
The kid from home alone calls it tough to sit down the next day.
Old April 11th, 2005, 04:53 AM   #8
I had to make some changes. The whench thing was not working for the adjustment. I removed the 10x1.5 bolt and got a longer one, the found a 3/4" nut, 3 12x1.5 bolts, cut the heads off the botls at a 15 deg. angle, and welded them to 3 of the flats. I then slightly rounded the 13mm head of the 10x1.5 bolt and pressed it into the 3/4" nut and welded. I now have a three handle adjuster. It works much better. And yes, pic.s are on the way.
