Threads: 32,361
Total Online: 598
Old December 29th, 2009, 05:54 PM   #1
flatheadgary
Default '67 pan
i have a '67 standard pan without the front beam. i know the early ones won't fit but, will a '68 and up fit? i figure trying to find a '67 might be tougher, so hence the question.
Old December 29th, 2009, 06:06 PM   #2
Default Re: '67 pan
yes
Old December 29th, 2009, 06:40 PM   #3
bluehormachea
bluehormachea's Avatar
Default Re: '67 pan
our rods a 63 on a 67 pan
bluehormachea is offline   Reply With Quote
Old January 1st, 2010, 07:22 PM   #4
63 hoody
63 hoody's Avatar
Default Re: '67 pan
any ball joint bug beam will fit , you can even switch around between 5 lug and 4 lug drums since 67's where 5 lug and ball joint and 1968 and later where 4 lug , thats how my bug is , its a 1963 body , 1969 pan , 1972 beam , 1969/1967 mix matched control arms , 1969 spindles , 1967 drums and 1969 backing plates nd brake parts . its all the same and as you can see from my pile of junk it all fits together fine , jst my 2cents
I finally found a substitute for ducttape ... JB WELD!!
63 hoody is offline   Reply With Quote
Old January 2nd, 2010, 02:31 AM   #5
dt113
dt113's Avatar
Default Re: '67 pan
One out of a Ghia (disc brakes) will also fit.
