Threads: 32,361
Total Online: 602
Old January 6th, 2010, 09:36 PM   #1
Chugger
Chugger's Avatar
Default WHAT IS IT ??
What the hell is this for? It is bolted to the tunnel in the seat belt mounts. Car didn't come equipped with seat belts, but the mounts are there.
MOVING SLOW, BUT STILL FORWARD
Chugger is offline   Reply With Quote
Old January 6th, 2010, 09:48 PM   #2
Ike59
Ike59's Avatar
Default Re: WHAT IS IT ??
Your car did originally have seatbelts. That's where the lobster claw type buckle latched onto for both front belts.
The latches were noisy and unreliable, and not continued after '67.
Ike59 is offline   Reply With Quote
Old January 7th, 2010, 12:05 AM   #3
Reaper
Reaper's Avatar
Looks like part of a can crusher, for aluminum cans, just missing some bits.
But yeah, what he said.
-Keith
Old January 7th, 2010, 12:19 AM   #4
gravguy
gravguy's Avatar
yes its a seat belt mount. yes i have the other half of it came in 3 different styles of loops and 4 different styles of the part that hooks to it
Old January 7th, 2010, 07:21 AM   #5
UT-X
UT-X's Avatar
It's for the passenger ejector seat. You should probably hook that back up.
Old January 7th, 2010, 10:31 AM   #6
Its to handcuff your date to.
Old January 7th, 2010, 10:42 AM   #7
Ike:
I had something shaped the same but round tube the whole length in my '72. I took it out because the seat belt straps were non-self-retracting, rotting, and the passenger one was sliced halfway through :P
I'm much happier with my $20 a piece non-retractable lap belts :P
Old January 7th, 2010, 03:26 PM   #8
Chugger
Chugger's Avatar
If only it was a can crushing, ejector seat, handcuff mount? You guys never fail to inform and, amuse. Thanks for the info, I've never seen that style of seat belt. I've got an old set of Simpson 3"lap belts that will be a lot safer.
Old January 8th, 2010, 09:53 AM   #9
Stray Catalyst
Stray Catalyst's Avatar
Early BMW's had the same kind of seatbelt loop, but I haven't seen one since before I could shave...
Stray
