Threads: 32,359
Total Online: 3593
Old January 7th, 2010, 07:34 PM   #1
slow74
slow74's Avatar
Default throw out bearing question
probably nothing to worry about but when my old man put the 71-up tranny in the 69 ghia we ran into the issue of having the wrong pressure plate since he put a 69 style in. waiting for the new one i thought about it and is the throwout bearing going to be different also or am i ok
slow74 is offline   Reply With Quote
Old January 7th, 2010, 08:01 PM   #2
Default Re: throw out bearing question
I believe they are different but i have not studied them both real close. But would make since they are different being as one needs the collar and one does not.
Old January 8th, 2010, 04:56 AM   #3
You can remove the guide sleeve and use the earlier T/O bearing or use the later pressure plate for the trans as is.
Old January 8th, 2010, 06:17 PM   #4
slow74
slow74's Avatar
ok well as is stands i will have the later pressure plate and earlier t/o bearing....so if i read correctly i will be fine with that setup
