Threads: 32,421
Total Online: 216
- by f4u5t
Old June 8th, 2017, 08:21 AM   #5826
I think you two had some holes chewed into your brain. This whole scheme is hairbrained at best.
Old June 8th, 2017, 08:26 AM   #5827
Coming from you, we'll take that as a compliment!
Old June 8th, 2017, 09:40 AM   #5828
We prefer to think of our "whole scheme" as thinking outside of the 'ol tool box.
Old June 8th, 2017, 10:21 AM   #5829
My toolbox consists of 3 broken drill bits, a half empty bottle of aspirin and a dry bottle of powerade. Heading out to sharpen bits in a few minutes...
Old June 9th, 2017, 03:19 PM   #5830
I didn't know that Snap-On made powerade.
Old June 9th, 2017, 03:50 PM   #5831
Never owned anything by Snap-on. Don't have that kind of money!
Old June 9th, 2017, 04:51 PM   #5832
Well, I have a genuine Snap On 3/8" drive ratchet with a matching 7/16" socket . I found them about twenty years ago at the edge of the road while heading to work.
Old June 9th, 2017, 07:52 PM   #5833
I have a WHole BUnch of Snap-on tools... but I mechanic for a living... gotta have decent tools or pay the price in time spent jacking with inferior stuff... I have MAC, I have Craftsman, and I also have some rarely used Harbor Freight items as well... Some Stanley, Proto... you name it. But the Snap-On tools are the best. I paid a fortune for the ones I have. Couldn't live without My Snap-On Ratcheting Screwdrivers... I have MANY of them... and they're only about 50 bucks a pop nowadays... I bought a long time ago and none of mine were that high... but they were in their day.
Mechanickin' for a living gives you a solid reason to buy some things that would otherwise be nonsense purchases. Sometimes you buy them due to the convenience of not having to go shopping for them, when the truck shows up and you have just had it with a crap tool. I spoil myself sometimes too... Not many of you guys are likely sporting the S-Shaped wrenches or Offset open end wrenches for limited access work... No matter where you buy those... You shell out more than you would expect. Garage Sales are a great place to buy good used Snap-On or such tools.
Old June 9th, 2017, 09:48 PM   #5834
marnat3
marnat3's Avatar
I have bought many Snap-on and Mac tools at estate sales and garage sales. Mostly because the people having the sales have no clue how to fix anything . They just buy or replace it , not repair it.
Old June 9th, 2017, 10:10 PM   #5835
The beetle was stalling out when at stop signs.. hills, intersections. It was as if the engine wasn't having enough omph to go anything. Prior owner claimed to have issues with the ignition cook which has a grounding strap which goes to the hood latch.
Fixed that and everything is better. Repair was swapping out the screws sanding down the corrosion, and using electrical grease so it doesn't happen again.
Old June 11th, 2017, 09:52 AM   #5836
It's true. BUying quality tools for what you do is the best way to go. When I was teaching (I miss it.) I bought this new laptop, totally tricked out, so I could run Photoshop, Corel, AutoCAD and Internet all at the same time. Never got lag from any of them on this thing. Not completely happy with a few things but so far, it's a beast!
Just bought a Lincoln welder and have plans to get some more stuff in the future when the money tree grows back.
Old June 11th, 2017, 07:27 PM   #5837
BadAttitude
BadAttitude's Avatar
Slowly working on the 1915 Turbo...I wish I was as rich as the carb dropped a few jet sizes, still rich so now I'm on too adjusting valves and timing, although any of you know what to set timing at by looking at the Dist?
"We'll just make a flange and zdus it back on!"
BadAttitude is offline   Reply With Quote
Old June 11th, 2017, 08:35 PM   #5838
I can't make a VW engine run further than I can throw one.
Old June 11th, 2017, 09:54 PM   #5839
Which is why I run a V8. As to yesterday, I pulled the Edelbrock carb off the V8 because the truck started running rough, needed the mechanical choke on all the time and I couldn't dial in the right side idle mixture screw. In fact, I could remove it without a change in the idle. A couple of years back I pulled the same carb for the same reason and found the inside looking like someone had left bits of rubber cement everywhere. Yesterday it was the same thing, bits of gummy crap everywhere. so I cleaned it out, blew out all the orifices, put it back on, this time with a pair of fuel filters. She fired right up and went into a smooth idle. Pulling onto the main road I lit up the tires and all is very well.
I'd pumped out a bunch of the gas from the tank and it looked okay. But when I built the 23 gallon mild steel tank back in the mid-89's, I sloshed the inside with a tank sealer to prevent rusting. My theory is that the crappy gas available here is causing the sealer to break down. I have a line on a 15 gallon stainless tank which I'll go with. I also have a brand new ten gallon aftermarket stock tank which with a small mod will fit, but I don't know if the sealer inside will hold up. Any thoughts?
Old June 12th, 2017, 04:57 AM   #5840
Man.... I just don't like Tank sealers... I've had nothing but trouble with them and for a variety of reasons... For example: Powder coating Motorcycle tanks is fun until you try and coat one with sealer in it... Major mess... Using stripper on it even adds to the mess.
Old June 13th, 2017, 09:52 AM   #5841
Repeat but not a repeat. For the past 2 weeks, in between my job, extreme heat, high humidity and rain.
Truck #4, 3rd time this design. Different fender lettering, pinstriping and tailgate.
Getting 'aged' today with wet sanding, and it leaves after 5pm.
Old June 13th, 2017, 11:55 AM   #5842
Hey Ms. Purp, there's a real art to the 'aged' look and your work is brilliant as always!
Old June 13th, 2017, 01:29 PM   #5843
marnat3
marnat3's Avatar
I second that.
Old June 13th, 2017, 02:45 PM   #5844
Thanks guys.
Is it just me or are there no pics there?
I put 3 links to photobucket.
Old June 13th, 2017, 02:51 PM   #5845
Figures~ I just tried poasting links in facebook and they don't work, yet pics are still in photobucket I hate technology sometimes~
Old June 13th, 2017, 02:54 PM   #5846
I was just avoiding the attachment way since half the time it doesn't work either~
Old June 13th, 2017, 06:05 PM   #5847
I work in industrial maintenance. I need good tools, but sticky fingers like them, too. So it's a delicate balance of good tool vs tool I can afford to lose or have stolen
Old June 13th, 2017, 06:31 PM   #5848
There is that... Good tools are rather attractive to people who don't want to pay for their own stuff... I don't have any issues with that where I work, but I certainly treat mine like there is a problem... Keep 'em secure as possible.
Old June 14th, 2017, 08:49 AM   #5849
Back when I was taking Auto Tech classes on the GI bill, I was also a TA. After hours we got to use the facility for our own projects. With the Tool Room closed we brought our own. One guy was known for 'borrowing' tools, only returning them if he got caught.
One evening he went out to his car, a pretty nice Camaro sporting American mags. The front wheels were missing and there was a note: "I like the mags, so you can keep my torque wrench." He borrowed a couple of the Chevy wheels from the shop's little 'bone yard' to get home. A couple of nights later at least three guys mentioned that their torque wrenches, a timing light and a few other things had mysteriously returned.
Nope, his mags never showed up.
Old June 14th, 2017, 10:54 AM   #5850
Risky but genius move
what did you do, yesterday
