Threads: 32,364
Total Online: 806
Old January 3rd, 2010, 03:00 PM   #1
flames2go
flames2go's Avatar
Default water jet service needed
Does anyone know of a water jet service they would recommend, need to have 2 lake pipes caps cut, have the aluminum and full scale drawing
If you think you have enough horsepower, think again, there's never enough!
flames2go is offline   Reply With Quote
Old January 3rd, 2010, 05:24 PM   #2
Default Re: water jet service needed
Probably cheaper to buy a jig saw, and hand file.
Old January 3rd, 2010, 05:34 PM   #3
wlfhwk1
wlfhwk1's Avatar
I agree with Unkl Ian, either do it yourself or just take it to a local machine shop. Having it cut on a water jet is over kill for someting that simple. There should be plenty of machine shop options for you up there.
Just cut it out and leave a good amount of material when you cut it out. Then just take your time filing it and shaping it by hand.
Originally Posted by Timbo View Post
Thats a big ol bucket of fuck
Originally Posted by 38Chevy454 View Post
Easy and cheap, two of Volksrodders favorite words. Works for car parts or girls
Originally Posted by tobiism View Post
I didn't mind the bra but it would look better with it off.
Doesn't everything?!?
wlfhwk1 is offline   Reply With Quote
Old January 4th, 2010, 06:58 AM   #4
Depending on how think it is, you could also use a router to do the work. You could make a wooden template & cut it close, then use the router (w/carbide bit w/roller bearing) to get the finish shape.
You've got to check out some of the stuff this guy made for his car.
