Threads: 32,346
Total Online: 504
Old March 19th, 2012, 08:32 AM   #151
Default Re: BEAM EXTENDER "FAQ" THE BASICS 101
Originally Posted by Jeff Pugesek View Post
My biggest question is, how much of a drop as far as spindles go after dropping down the 2.5 from the extension? I know tire size will play a roll in this too.
Also factor in an adjustable beam. Where the adjusters were clocked when welded in, even with the 2.5" drop on the extender, and 2" drop spindles, We still dropped it a good bit more with the adjustable beam to get a ride height we all liked. stock height beam jsut wasn't low enough for wehat we were looking at with 4.5". IIRC with a couple of our fat asses sitting on the front with the adjusters totally bottomed out, we were about an inch off the deck at the actual frame head.
Old March 19th, 2012, 09:26 AM   #152
Jeff Pugesek
Jeff Pugesek's Avatar
That's what I was lookin for. Thanks.
Jeff Pugesek is offline   Reply With Quote
Old March 24th, 2012, 10:41 AM   #153
Jeff Pugesek
Just got my 10 inch extension in the mail. Need to get the baja outta storage in a few weeks and start the project. Can't wait. Drop spindles and disc brakes to come. Anyone have a line on a brake conversion kit for wide fives?
Old July 26th, 2013, 01:05 PM   #154
SlimJim
XXXXXXXXXXX
SlimJim is offline   Reply With Quote
Old August 2nd, 2013, 10:51 AM   #155
sandfreaks
sandfreaks's Avatar
As far as I know there are only kits for 4 luggers. So youll have to run 4 lugs in the front.
4 lug to 5 lug adapters hit the Caliper so those dont work either.
sandfreaks is offline   Reply With Quote
Old August 2nd, 2013, 11:56 AM   #156
Double D
Double D's Avatar
http://vwparts.aircooled.net/Wide-5-...bj-lowered.htm
http://vwparts.aircooled.net/Wide-5-...lp-lowered.htm
http://vwparts.aircooled.net/Wide-5-...t-lp-stock.htm
They are available
Old May 15th, 2014, 08:10 AM   #157
punkabilly
punkabilly's Avatar
ok guys here is my stupid question will the stock gas tank fit back in with 8in extender and brace? or will i have to buy another tank?
car is a 73 standard
punkabilly is offline   Reply With Quote
Old May 15th, 2014, 08:29 AM   #158
I have a '72 standard with a DBug brace.. I have 1 inch square tubing under the lip of my tank to raise it, but I THINK that was done because of how my steering column and u-joints fit..
edit: in order to accommodate having the bar stock under the lip of the tank to raise the tank 1 inch, you also have to buy longer bolts..
I'll try and remember to take a pic of two when I get home from work today..
Old May 15th, 2014, 10:26 AM   #159
I have an 8 inch beam extender made from some one else, can't remember who PO bought it
Any how the PO put in a round poly tank, one day I'm gonna put the stock tank back in, I believe you may need to raise it up a bit to clear everything, how much I don't know, once the beam extender & brace are on, set the tank in, then turn the steering wheel back & forth raising the tank up until it clears everything
Old May 15th, 2014, 03:49 PM   #160
punkabilly
punkabilly's Avatar
thanks guys i plan on ordering my extender and brace in near future gotta get glass cut for chop first but just wanted to know if i had to add a tank into ever growing order of parts
Old May 15th, 2014, 04:07 PM   #161
forgot about the pics until I saw your new post, so here they are :
This one shows the 1 inch square tube I used to support the rear side. It's just resting in place, held by the tank and the clamps, so when I remove the tank I have to grab it or it falls and makes a bunch of noise.. :P
a shot of the passenger side rear bolt.. see why you need longer bolts? :P
The front of my trunk was cut off, so HotRodHeb custom fabricated a wooden shelf out of 1 inch plywood so I can actually put shit in the trunk and not have it fall out :P
It rests on what's left of the metal frame pieces in front of the tank and the tank sits on top of it..
Old July 26th, 2014, 07:32 PM   #162
I have a question about the price of the beams and braces.. Since Volksrod shop website no longer shows the prices! What happened to the site?
Old August 8th, 2014, 04:05 PM   #163
heatmizer
Bottom of his contact page says he's temporarily not taking orders. I'm meeting a guy in an hour to hopefully finally get my 2 year delayed project off the ground, looks like it won't be a volksrod for a while.
update: 7/22/2014
The Products Page and Shopping Cart have been temporarily taken down due to the amazing amount of customer orders. Thank you. Thank you.
heatmizer is offline   Reply With Quote
Old August 9th, 2014, 06:39 AM   #164
Number1tileguy
Number1tileguy's Avatar
Doug (Volksrod Shop) recently had a death in the family,
He has taken it pretty hard...
Give him a little time to regroup and he'll be back doing the "Fantastic" work that he's know for 👍
Shoot him an email and I'm sure he'll get back with you when he's ready to start up again.
Thanks Guys,
I hope Doug doesn't mind me posting this on his behalf
Sent from my iPhone using Tapatalk
Until next time...
67' Volksrod 2276cc (sold)
72' Baja Champion SE 1776cc
66' Volkstruck 1641cc
Old August 9th, 2014, 10:29 AM   #165
Doug informed me yesterday that he'll be able to take orders next week. he's just ran into some issues. Nice guy. I saw the mojo thread and was shocked to hear what happened. Glad to see things are starting to get back to "normal" He's the only one I feel comfortable buying a beam from
Old August 7th, 2018, 07:55 PM   #166
dero
Originally Posted by Dbug41 View Post
Newbies Ask your Qestions here
Well the title says it all
I would like to call on all the Veteran Volksrodders out there to assist me in answering the many and wide variety of questions out there
The new people coming in Volksrodding are deserving of our knowledge and this will help keep the other threads clean as well when it gets moved to the tech bin
so newbies please ask away
and guys...um please play nice
Read this thread
Beam Extender Install Walkthrough
http://www.volksrods.com/forum/showthread.php?t=29832
and this one too
How to build a volksrod..OFFICIAL NEWBIE GUIDE!!!
http://www.volksrods.com/forum/showthread.php?t=5617
G'day, Can anyone tell me where Dbug41 is located. Cheers. Dero.
dero is offline   Reply With Quote
Old August 8th, 2018, 01:20 PM   #167
Hi DERO. You can reach Doug at doug.thevrshop@gmail.com he is ( I think) just moving into a new home and it may take him a couple of days to get back to you. If you don't hear from him pretty soon private message me and I'll get the two of you together.
Old February 16th, 2019, 11:32 AM   #168
bryon.alberty
Silly question. What do you do about the steering stabilizer if you go center steer?
bryon.alberty is offline   Reply With Quote
