Threads: 32,346
Total Online: 464
Old November 29th, 2018, 04:40 PM   #451
Wraithblade
Wraithblade's Avatar
Ron some time you need to make it back to my house. I have some sweet brakelight/turnsinals you can have they are LED and bright as hell plus I have some extra parts and a wiring harness you can grab as well.
Old November 30th, 2018, 04:28 AM   #452
Hey Wraithblade, too bad you weren’t around when I visited Ron. I wanted to see that chop.
Old November 30th, 2018, 10:04 AM   #453
Wraithblade
Sorry about that, Ron could have called life is just crazy right now would love to meet you sometime. Hell we have been chatting since my first chop here we are at my third and still haven't met. you have my number call anytime.
Old December 1st, 2018, 04:51 PM   #454
Once I get my car going I'll stop out, I should have had it fixed a few weeks ago but I don't wanna try taking the starter out with my dog on my belly or chewing on my feet, he has to be as close to me as possible
I hope to get it done by February, having cataract surgery Monday and on the 26th
Old December 7th, 2018, 02:02 PM   #455
Hey Ron!
Old December 9th, 2018, 09:33 AM   #456
Hi Keith, Nice to see you back in these parts.
Whatcha got for projects?
Heh heh heh - something up your alley for sure! We are working on selling the house this winter/spring - and then will be able to start work on it.
Hint: 986 is a key number for the chassis. 40 is a key number in the body.
Old December 12th, 2018, 04:22 PM   #457
Hey Ron!
Hey Keith
We today I found a way to keep my dog busy so I was able to fix my Volksrod, don't have any idea what was wrong but it starts with the key again
I pulled the starter off and tested it, it works fine, I put it back in and nothing, so I took a piece of wire and hooked it to the battery and touched the other end to the solenoid and it cranked over, so I got in the seat and turned the key, it fired right up
https://youtu.be/1lrKJ_aK26Y
I just need to adjust the valves, its a few hundred miles over due, I kept putting it off because I hafta pull the exhaust off in order to remove the valve covers, maybe tomorrow depending on the temperature
Now I'm no longer stuck at home without a car
Old December 13th, 2018, 03:50 AM   #458
Sounds like the Ol' Hard Start relay is in your near future... this is one of the many ways people start their adventures with old harness issues... this would be typical, so get a Cheap Bosch relay and get ready to install...
Old December 13th, 2018, 01:29 PM   #459
I have had a couple of those over the years - I think the first one was already installed on my '62 Baja - had to ask someone why I had a Ford solenoid under the luggage compartment - they asked if my car starts right up - leave it alone was the answer. Hope everyone is doing well.
Old December 14th, 2018, 03:54 AM   #460
I'm not a fan of going to the ford Starter Solenoid... although it does work OK... but they draw a ton more current than a simple Bosch relay... so I opt for the little guys. They do the job fin as the draw on the high side is still a very short distance at that point. You can even get a heavy duty Bosch relay (heavier windings and contacts) if the standard ones don't seem enough for you... But Hey! A Relay is a relay is a relay... like said... if your car starts good, doesn't matter.
Old December 14th, 2018, 10:25 AM   #461
My Single Cab starts just in just a 'ducky' manner with it's Ford relay. Of course, it also has a Ford engine among the other Ford parts.
Old December 14th, 2018, 04:23 PM   #462
Well... There is that option... Probably not going to fit in a Beetle so well though... I sell and install a lit of Small engines in Machines of a sort... a lot of the machines have their own Sarter systems electrically wired in and an on board Solenoid (separate from the engine starter). Most of the Engines we sell also have a Small Starter solenoid on them. It is almost just like a ford solenoid, but much smaller and the specs are just slightly higher than the Bosch relays... but buying them from Briggs is preventive on price, so I recommend the Bosch. But personally I would use one of the ones we remove from the engines we install, as I can get them before they reach the trash and have a small stash of them. Briggs and Stratton has them on their smaller V-twin engines. 17 but on Amazon though, ain't too bad. Click the link below for Amazon site ad
Starter Solenoid
Old December 15th, 2018, 11:33 AM   #463
horshak
Word for word what I said on my '63 it happened 5 times in 2 yrs. Replaced the starter too. Turns out it was a bad battery ground cable. Pulled it off and put a ohm meter on it. Compaired it to the positive cable reading. Much higher resistance. Replaced it no problems in the past 8 months.
horshak is offline   Reply With Quote
Old December 15th, 2018, 07:02 PM   #464
This seems to be a common issue as well... the Bonding straps are known for failure due to corrosion. The old wires from the battery, to the ignition switch, back to the starter is a long distance in wire, and corrosion (the same issue as the Bonding strap gets) causes the "no start" situation usually too. lowering the demand to the draw of a relay instead fo the starter mounted solenoid, usually does the trick if it's not the ground strap.
I recommend testing and replacing both if you can verify the issues.
Old December 16th, 2018, 01:56 PM   #465
I don't think 'too much ground' is possible. I ran extra ground wires to my tail lights when I started having problems with the brake and turn signals. There are also extra grounds to the headlights. I also have a heavy braided ground cable running from an engine mount bolt to the truck's 'frame.' Once a year or so, I unfasten them to clean and grease the contact points. My battery's ground cable runs to the same motor mount bolt.
Old December 21st, 2018, 10:10 PM   #466
I put a Ford solenoid on my rail buggy and my 66 when I changed it to 12 volts, as for now I'll just wait till it acts up again and put a Bosh relay on, eventually I plan to buy an undated wiring harness for it
Thanks for the info Scott
Old February 13th, 2019, 10:37 PM   #467
Well today my Volksrod is roadworthy once again, my registration expired and we had to try to save every bit of money due to the GOV shut down, Trina had to work without pay, but once they opened back up we got a check within 3 days, it's hell getting down to the last bit of food left in the house
On the bright side I was able to renew the registration on the Volksrod yesterday (2-13) I haven't started it since January 5th, it fired right up this afternoon, tomorrow I'm gonna take the dog to the park and walk weather permitting, before the snow we had on January 11/12 I was averaging 18 miles of walking a week, 5 months since I gave up the pain meds, I hurt like hell, but as long as I stay moving it isn't that bad, we had our first dry sunny day here in weeks, the Ohio river peaked about 24 hours ago and will go back up again this weekend, we would be up to our shoulders in snow if it was snow (thank god for warm weather, if you don't like it in Cinci just wait a few days and it will change, we have all 4 seasons in a month these days
As we brace for another possible money less future this Friday Trina has already been told she has to be at work every day, luckily we stocked up on plenty of food just in case, I was getting Ramen Noodle souped out
Ok on to better things, I'm debating an engine swap in the Volksrod, I have the 2001 Ford Escort ZX2 2 litre DOC that with an adapter would really add HP, IF I do it I plan to flip the trans and make it a mid engine, I started building a custom floor pan years ago, would be very easy to change, the ZX2 was quick and topped out around 140 mph in 5th gear at 2000 rpm, best part is heat, just one of those things I know I can do
Well enough about that, I still need to deal with a cra cra 8 month old dog that requires every minute of my attention, I'll share some pics in the pet thread tomorrow
Old February 14th, 2019, 08:53 AM   #468
I built a bench in the basement and modified my engine stand to have 4 wheels. Going to start to build a 90.5x78.8 screamer. I hope I can carry the short block up the stairs. Actually I hope I can get to that point before life gets in the way.
Old April 15th, 2019, 04:13 AM   #469
Not, yet. But, maybe soon. Just have to agree on a price. 73 standard. No floors, some C pillar rust. I plan on chopping the roof.
Old April 15th, 2019, 05:17 AM   #470
Got a lead on a cheap 73 super. If I got it, it would be to 0art out. Need to sell my manx and cut up my volksrod for scrap.
Old April 15th, 2019, 07:03 AM   #471
Yeah, I would have to cut up a body that I attempted to chop. But learned a lot on it. I hope I can get this cheap.
Old July 30th, 2019, 11:27 AM   #472
After sitting for almost 3 months my Volksrod is alive again, I bought a battery for it the first week of June, that got it going, but I had issues with lights, so I let it sit, yesterday it wasn't to hot out, it had been sitting in the street and I don't like working on anything in the street, turns out it was just a battery cable, I just need to adjust the valves
I was getting spoiled with a/c and heat for the last year
Old July 31st, 2019, 11:44 AM   #473
I have been getting spoiled too - driving my first car with A/C for the past week - waiting on rotors to get Vivian back on the road. Don't tell her that I have enjoyed the new car....she would get jealous and it would cause something else to break, LOL
Old September 21st, 2019, 04:55 PM   #474
I can't remember how many years ago I made this disc brake setup for the rear of my Volksrod, it's off of a 92 Honda Accord, I had to buy new calipers, then find all the parts, that was the difficult parts, I drilled my hubs to fit the wheels and got rid of the adapters, I still need to attach the e-brake cables and make a bracket for the rubber brake line
Old September 22nd, 2019, 08:14 AM   #475
Cool. So you collected and fab’d everything a while back and just getting around to installing them?
