Total Online: 228
Old September 14th, 2014, 09:37 PM   #26
Default Re: 70 VRod
Do away with the original hinges & put some on the outside, that's what I plan to do if I ever get to chopping mine
Seems somebody has a deck lid hinges on the outside, I just can't remember who it is
Old September 15th, 2014, 03:38 PM   #27
Default Re: 70 VRod
49 Ford Deck hinges would do nicely if you can manage. They're heavy and Chrome... and not really all that common. Would look pretty cool I think.
Old September 15th, 2014, 07:01 PM   #28
Default Re: 70 VRod
That's exactly what I was talking about, when I get around to chopping my top, I planned to use use hinges like those, that's if I decide to keep the deck lid
Old September 15th, 2014, 07:54 PM   #29
Default Re: 70 VRod
Because of the deck lids compound curve, you'll want the hinges close together and aligned so that they don't bind as they pivot. Or, one wide VolksRods'esq (esk?) centered hinge would do.
Old September 15th, 2014, 09:10 PM   #30
Default Re: 70 VRod
You could always get a puma shroud? Or Didn't somebody here make one? I think i saw a thread on it.
Old September 15th, 2014, 11:53 PM   #31
triker_Chewie
triker_Chewie's Avatar
Default Re: 70 VRod
new deck made of leather dzused on?
Bodger's Paradise my blog
triker_Chewie is offline   Reply With Quote
Old September 16th, 2014, 05:04 AM   #32
roudyb
roudyb's Avatar
Post Re: 70 VRod
I stand by my earlier post! I was going to add some dumb remark about your, ahem, "smoking hot chop," but I'll pass.
I can see we are going to get along quite nicely. I appreciate the free pass but as an ex-jarhead banter is welcomed and expected.
I will fire the first shot across the bow with, "What if" the water-bottle extinguisher didn't work:
Smoking Hot Chop, that should be the
new name of the thread
roudyb is offline   Reply With Quote
Old September 16th, 2014, 05:09 AM   #33
roudyb
roudyb's Avatar
Post Re: 70 VRod
How much of the 'valley' of the hinge mounts do you need for the lid to flip up? I was thinking that you could run some flat material straight across the hinge mount high enough to miss the shroud, losing the lower part of the curve.
That's a good point. My first thoughts were that the hinge would have to be modified to some extent i.e. shortened, bent, etc. Just was checking if someone actually modified the hinges for a reference point.
I will have to study it more. I'll check what sort of clearance I have and get back to you.
Cheers
Old September 16th, 2014, 05:13 AM   #34
Default Re: 70 VRod
That picture makes me feel sad for a super then again I see viable parts from the damn thing
Old September 16th, 2014, 05:13 AM   #35
roudyb
roudyb's Avatar
Default Re: 70 VRod
Hi Ron. I originally had the same thought but as the evil plan progressed I am going for a vintage look, 30s/40s roadster while keeping most of the VW features. Not to say I won't go off the beaten track but I would like to keep clean lines with touches of chrome and whitewalls, of course.
Really enjoying your build. Those wheels you are building are bananas. Wish I had the tools and know how to do it. Keep up the good work.
Cheers
Old September 16th, 2014, 05:16 AM   #36
roudyb
roudyb's Avatar
Post Re: 70 VRod
That is slick. I'll have to give it a rethink. Could make my life easier. I'm off to pull the engine now and replace a few gaskets and such. The car has to be moved out of the shop it's in now and I had better get her running properly.
Cheers
Old September 16th, 2014, 05:17 AM   #37
roudyb
roudyb's Avatar
Post Re: 70 VRod
Hmm. One hinge... interesting.
Old September 16th, 2014, 05:18 AM   #38
roudyb
roudyb's Avatar
Post Re: 70 VRod
Would like to see a pic of that.
Old September 16th, 2014, 05:19 AM   #39
roudyb
roudyb's Avatar
Post Re: 70 VRod
Not familiar with the set up. Any reference for it?
Cheers
Old September 16th, 2014, 05:21 AM   #40
roudyb
roudyb's Avatar
Post Re: 70 VRod
Fire and VWs are two mortal enemies whose paths should never cross. Otherwise, get out the marshmallows.
Old September 16th, 2014, 05:47 AM   #41
roudyb
roudyb's Avatar
Post Re: 70 VRod
Fender Well Cut
Okay, so where were we. Another inch to come down and it was the secret cut pointed out by FC&M where the fender well had to be cut and pushed in.
This will allow the chopped top to drop into place. I only realised at this point that the back was too high and needed to be reduced in height and pushed inward to meet the modified shape of the tail now that the top has dropped down to a more narrow line.
Old September 16th, 2014, 03:28 PM   #42
roudyb
roudyb's Avatar
Post Re: 70 VRod
Fender Cut Detail
Here's the cut and it moved inward pretty easy.
And voilą the C-Post butts up nicely
And that 1" gap on the B-Post is no mo
Going to have to warm up the saw again
Old September 16th, 2014, 04:38 PM   #43
bulletbug
Default Re: 70 VRod
that is a very cool solution to the problem. Great Job!
bulletbug is offline   Reply With Quote
Old September 16th, 2014, 04:57 PM   #44
Default Re: 70 VRod
Cheers
Thank ya, I hope next year to have all 4 wheels complete, 10" wide on the rear & 6" wide up front, I have the metal rolled up, I just need to finish cutting the wheels in two, then buy tires, I see that part taking the longest
Ya know, that almost sounds cool, may hafta see if I can whip something up
Old September 17th, 2014, 07:46 AM   #45
theredbarn
theredbarn's Avatar
Default Re: 70 VRod
If I decide to run a deck lid, I'll just use pins or Dzus fasteners and forget the hinge.
Old September 17th, 2014, 07:55 AM   #46
roudyb
roudyb's Avatar
Post Re: 70 VRod
Squeeze & Window Shape
With my handy strap we squeeze the bottom C-Posts inward to meet the roof top C-Post. This shows how much the top has moved forward from the original position.
Now the side-rear window has to be reshaped. So the original bottom curved area has to be cut out and angled upward to meet and continue the overall window shape.
At least that's the plan
Old September 17th, 2014, 07:59 AM   #47
roudyb
roudyb's Avatar
Post Re: 70 VRod
Cheers. Working away, first custom rod ever so blindly enjoying Mr Toad's wild ride. Ha!
Old September 17th, 2014, 11:04 AM   #48
Default Re: 70 VRod
Ya know, after seeing that, when I get to doing mt roof, I'm gonna bring the body up to meet the roof, take it out behind the doors, depending on how low you go, it may be far enough forward to clear the fan shroud, it'll be sticking out, but then ya wont need a deck lid
Old September 17th, 2014, 11:28 AM   #49
roudyb
roudyb's Avatar
Post Re: 70 VRod
Side Window Nip Tuck
Okay this, along with the previous cuts, is a little tricky. Trying to keep symmetry for both sides and get a smooth curve for the framing of the glass.
Old September 17th, 2014, 11:40 AM   #50
roudyb
roudyb's Avatar
Post Re: 70 VRod
Unfortunately here in Ireland with all the rain and no deck lid my engine would turn into a swamp cooler.
I do like the look of these hinges:
1970, beetle, fernon chop, volkswagen, vrod
