Threads: 32,359
Total Online: 1631
Old April 28th, 2010, 01:25 PM   #76
Default Re: The wife's new 66.
Concidering to re-paint the exteriour myself too....
Was thinking if I could mount the fenders on the body with longer bolts so I could paint them the same time and be able to get the paint penetrate in behind the fender beadings too. Just like in this factory picture:
Old May 1st, 2010, 11:14 AM   #77
Sanded off the spraycan Seesand off the fender and also paintstripped the area where I had hammered out a big dent.
I think I did get the dent out pretty good.
Old May 1st, 2010, 11:59 AM   #78
vdubjim
veteranen service :)
Jim Buys
Vintage Speedwerks
Vintage VW's and CUSTOM Vinyl Graphics
Oklahoma VW Club
www.oklahomavwcruisers.tk
vdubjim is offline   Reply With Quote
Old May 1st, 2010, 12:04 PM   #79
Haha. Sharp eyes...
Didn't notice it myself. Been laying on that table for ages...
Old May 2nd, 2010, 08:24 PM   #80
Left frontfender filled, sanded and covered with primer. Rest sanded down with P800.
Old May 5th, 2010, 11:34 AM   #81
Inside finished and started to fit the panels.
Old May 6th, 2010, 06:49 PM   #82
Boom
Boom's Avatar
looks awesome man I have a question of the tail lights, I have a 67 with the same lights are they euro?
www.dlkweb.org
Boom is offline   Reply With Quote
Old May 7th, 2010, 08:13 AM   #83
Yes, I would guess they are Euro tailights.
When I was going to mount the case oilcover in the bottom I found out that the PO had pulled the threads for one stud...
Luckily they had the Wurth's Time-Sert set at my work so I got new threads for the stud easily. Now the engine should not mark it's spot due to that...
Old May 7th, 2010, 12:44 PM   #84
Al Low Ha
Al Low Ha's Avatar
Nice job on the engine Hebster! Fantasy Factory speed look!
When you contact VwVeteranen again tell Klaus (Uzo) Herr Kritz says Hallo! I've spent many many days digging thru his goldmine! Good Times!
The plastic vapor barrier on the doors is SO important....yet I too rarely see it any more.
When painting the exterior, so many guys paint each part(doors-fenders-hood-decklid-light housings, etc..) off the car.....and thats why on SO MANY cars the paint appears to be slighty off color between components,...slightest variations in temp/humidity/evaporation of solvent/exhaust flow/etc.. can make large changes to the finished color... YES, do paint your car like the cool old factory foto....you'll get a nice even colored paint job!! Can't wait to see it all sprayed and assembled!!
Aloha!
Old May 7th, 2010, 01:13 PM   #85
Thanks for your support!
I will be spraying it tomorrow. So I will have to get to bed now so I can start up the preparations early tomorrow.
(Where's that spraypaint smilie...??)
Old May 8th, 2010, 09:30 AM   #86
This morning:
In the afternoon:
Looks like a Kommanderwagen as it sits now...
Old May 8th, 2010, 04:33 PM   #87
Al Low Ha
Al Low Ha's Avatar
Looking good Hollywood!
Nice syncro inthe background!
Aloha
Old May 8th, 2010, 08:00 PM   #88
Looks great!!
Old May 8th, 2010, 08:46 PM   #89
Nice job!!! What are you guys allowed to spray over there, or what did you use? When I go to Norway to teach, they all use the PPG Enviro system. Works pretty good.
Old May 9th, 2010, 11:38 AM   #90
I used Standox acrylic 2k paint. The paintshop had some oldstock acrylic they could mix the colour from. Getting more and more hard to find real acrylic here too...
Thanks guys!
I guess it is ok.
Did do it myself and outside. Unfortunately the spring had got that far here now too so the small insects thought it would be fun swiming in the paint...
Got a few spots where they got stuck. Decided to just squize them lighty into the paint so they wouldn't crawl all over the car. That way I should be able to polish off them leaving just minor marks from the tiny legs...
Old May 9th, 2010, 11:40 AM   #91
Old May 15th, 2010, 10:26 AM   #92
So, started sanding down the new paint.
And then refurbish it again.
First sanded it with P1500, then some 3000 and then polish.
See the difference in the finished fender (to the left) and the non touched orangepeel on the quarterpanel to the right..
Old May 15th, 2010, 12:02 PM   #93
YAY buffing ! Thats actually what I am taking a brake from right now. My feet are wet, my hands are soggy and my shoulders hurt. On the bright side, I'm getting paid for my job
Old May 15th, 2010, 12:44 PM   #94
How do you do the buffing? In this case I simply sanded down the orangepeel with some Polarstar P1500. (drysanded with a random orbital DA) Just to smooth out the hispots of the orangepeel.
Then wetsanded with Abralon 3000 to get up the gloss again and finished with Polarshine rubbing compound.
Will still apply a layer of Simoniz wax for protection too.
Old May 15th, 2010, 04:18 PM   #95
I've got the wet DA at the shop. Start off with the runs and dirt getting them taken care of with a razor blade and 1000 grit. Then jump into it with 1500 on the DA wet and then wet 3. Half the time after the 3000 you almost don't even need to buff it. I go over it with a rubbing compound and a gray pad and finish it off with a swirl remover/waxing compound. Its not really that hard of work, but by the time you're done you don't ever want to see a buffer, car, or even hear the work "wax" again
Old May 17th, 2010, 03:47 AM   #96
Engine finished. Just need to buy a new fanbelt and mount it to the not yet finished testing bench so I can test start it in the bench.
Old May 20th, 2010, 07:32 AM   #97
Old May 20th, 2010, 08:18 AM   #98
Cat Box's Avatar
ohhh thats pretty.
nice work as usual.
Old May 25th, 2010, 09:40 AM   #99
Old May 25th, 2010, 09:44 AM   #100
Budreaux
Budreaux's Avatar
Clean..... nice job Heb.
callook, oldspeed, seasand, seesand
