Members: 17,576
Threads: 32,321
Total Online: 591
Newest Member: Wozza
- by bigguy
Old October 12th, 2004, 10:56 AM   #26
PAPA_SMURF
PAPA_SMURF's Avatar
just make your own, its alot easier and the rod should not cost more than $5.oo. I added 15 inches to mine and still have more rod to make another.
...Joey
66 schwinn, 04 Jetta
vwclubofhawaii.ning.com
PAPA_SMURF is offline
Old October 12th, 2004, 11:06 AM   #27
dez
you CAN NOT just swop early and late shift rods over. theyre a different length. they changed at the end of '67, the same time as the slot in the cup dissapeared, cos vw went from the tapering swan-neck shifter to the straight constant diameter one.
measure,measure,cut,grind,test fit,grind, hit/bash,grind,test fit,bash,grind,swear,grind,swear again,bash some more,tack weld,bash,weld...........'there, i told you it fits!'
dez is offline
Old October 12th, 2004, 01:34 PM   #28
Yank your shift rods out and put a notch in it. Its easy, so easy there is really no excuse for trying to find a dozen ways around it. Just Grind the damn notch lube it up well and shove that bitch back in there.
I added this reply becuase this thread has been recycled. Just incase any Newbies are looking at it.
Jon is offline
Old October 12th, 2004, 02:14 PM   #29
Moderator
Originally posted by Jon@Oct 12 2004, 02:34 PM
Yank your ... rod out ... lube it up well and shove that bitch back in there.
Automotive customizing
or
Porn
You be the judge!!! [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img]
hotrodheb is offline
Old October 12th, 2004, 02:40 PM   #30
Originally posted by spiggy@Oct 12 2004, 12:17 PM
anybody tried fitting a scat bus shifter in a bug???
Look on my intro for pics and details.
bugdust is offline
Old October 12th, 2004, 07:46 PM   #31
spiggy
Originally posted by bugdust+Oct 12 2004, 10:40 PM--><div class='quotetop'>QUOTE(bugdust @ Oct 12 2004, 10:40 PM)</div><div class='quotemain'><!--QuoteBegin-spiggy@Oct 12 2004, 12:17 PM
Had a look at ur intro cant see no scat bus shifter on there [img]style_emoticons/<#EMO_DIR#>/confused.gif[/img]
Anybody else got any ideas???
Knew you'd be pleased................................
spiggy is offline
Old October 12th, 2004, 08:07 PM   #32
crack monkey
crack monkey's Avatar
i have a hurst bus and i need to get a smaller steering wheel to work it. i cant get reverse with the way it is now
crack monkey is offline
Old October 13th, 2004, 05:23 PM   #33
HMMMM...did you happen to see post #23? [img]style_emoticons/<#EMO_DIR#>/huh.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] There's more pics of the spacer I fabbed up on the link in my signature.
bugdust is offline
