Members: 17,576
Threads: 32,321
Total Online: 596
Newest Member: Wozza
- by bigguy
Old January 31st, 2018, 09:23 AM   #326
And a president who is not looking to get rid of military pensioners... for that whole 7 years ... dealio
Old July 19th, 2018, 03:44 AM   #327
well holy shit... it's been almost half a year since I updated...
We moved to Maryland in June, got our Virginia house on the market now, hopefully someone buys it son, two mortgages on one income sucks.. wife is looking for work, but everyone requires a degree, she's got tons of experience but no degrees.. I've been driving the bug regularly again. it seems to be running really god right now. But I think maybe my o2 sensor is either bad or not reading correctly.. by my guesstimates, I've got both carbs jetted crazy rich (I forget exactly what's in there, but I know I have 60 idles in, I want to say 200ACs and 115 Mains..) but the wideband guage says "AIR" probably 90% of the time, "Lean" about 8% and somewhere between 13 and 15 AFR the other 2%.. those random readings tell me it's jetted right, but for some reason it doesn't read consistently.. going to be checking over the exhaust when I get a chance to see if something isn't tightened down at the exhaust ports maybe, allowing fresh air to be sucked into the flow and screwing with the numbers. The rest of the pipes are slip fit, and tighter than a mother fucker, so I know there's no leaking at the joints.
I've also noticed my oil temp stays between 120 and 180, so I'm not overheating oil. and my cylinder temps are all between 150 and 290F. I'm guessing it has something to do with the missing engine tin, but cylinders 1 and 4 seem to run hotter than 2 and 3 most of the time.. which struck me as odd because they are opposite corners.. normally 1 and 4 are in the 250-270 range while 2 and 3 are around 180-220.. I know having that big of a temp disparity can't be healthy, but it sounds great, runs hard, and is too much fun to stress out now.. i'll do that when it explodes :P
anyway, I gotta get to work.. I'll try and update more later.
Old December 2nd, 2018, 11:12 AM   #328
Had it running and was driving daily for about a month..
One day I had a road rage incident, and shifted a bit too fast from 2nd to 3rd while trying to pass someone going uphill.. threw my belt.
Put a new one on, but didn't double check the backspacing, and threw it a few days later. Adjusted the spacing the best I could at the time and put a 3rd belt on. drove another couple of weeks before finally getting shims and time to do it properly, and when i pulled the alternator pulley off, found that it had been eating my alternator faceplate.
But I did buy the wife a new iPad last month for a combination birthday/christmas gift (her old one if a Gen 1 iPad.. it was dying a bad death haha..), so she just greenlit me to buy a new alternator for my own christmas (I'm using the $300 Compu-Fire 90amp one...)
so once i get that, I'll swap em out and hopefully get back on the road.
Old December 2nd, 2018, 11:24 AM   #329
Until I read what you've written, I thought you'd spent a lot of time polishing a alternator pulley.
Old December 2nd, 2018, 04:26 PM   #330
lol no, but before i saw the alternator damage, i did use "hmm, my current pulley is an OG german one, maybe it's warped" as an excuse to spend $110 on a JayCee billet pulley.... :P
Old December 3rd, 2018, 07:04 PM   #331
Howdy Folks!
How goes it Matt? Kim?
Old December 5th, 2018, 04:26 AM   #332
That sucks. As long as that damn key way is ok.
Old December 8th, 2018, 08:35 AM   #333
the keyway itself looks a little wider than it should and you can see on the key where it was wobbling a tiny bit..
new alternator should arrive soon, i'll probably throw this one somewhere in the garage under the pretense of an emergency spare and then throw it int he trash 10 years from now.. lol
Old December 9th, 2018, 12:32 PM   #334
new alternator in.
combination of the woodruff key on the pulley and being a little mangled, the slot being a little widened, and the small piece of the pulley that locks it all in place being worn down probably did it all in..
It's been parked for like a month, so it's on the trickle charger right now.. may need a gallon or two of fresh gas, but we'll see if it starts with a charged battery first..
