Members: 17,620
Threads: 32,327
Total Online: 412
Newest Member: Beanbox
Old August 19th, 2016, 02:04 PM   #26
V8 VolksRod
V8 VolksRod's Avatar
Default Re: V8 Volksrod Chassis
Driveshaft is installed. Fit very well.
[IMG]20160819_140109 by Ben Modified, on Flickr[/IMG]
Also got a set of headers for a very good price that I had ordered a while back. They do give me more clearance around the master cylinder, so no insulating wrap needed, but I really like the look of the roadster headers
[IMG]20160819_140119 by Ben Modified, on Flickr[/IMG]
[IMG]20160819_140143 by Ben Modified, on Flickr[/IMG]
For comparison
[IMG]20160815_150838 by Ben Modified, on Flickr[/IMG]
http://www.BenModified.com
V8 VolksRod is offline   Reply With Quote
Old August 24th, 2016, 03:22 PM   #27
V8 VolksRod
Started fitting the driveshaft tunnel, checking bench seat clearance. Had to air hammer off some left over spot welded floor.
[IMG]20160823_161531 by Ben Modified, on Flickr[/IMG]
[IMG]20160823_164337 by Ben Modified, on Flickr[/IMG]
Also cut out a large rust hole and welded in a new panel.
[IMG]20160824_171433 by Ben Modified, on Flickr[/IMG]
[IMG]20160824_171706 by Ben Modified, on Flickr[/IMG]
Old August 25th, 2016, 01:12 PM   #28
V8 VolksRod
Welded in the driveshaft tunnel today along with more rust repairs
[IMG]20160825_091223 by Ben Modified, on Flickr[/IMG]
[IMG]20160825_091700 by Ben Modified, on Flickr[/IMG]
Old August 27th, 2016, 03:45 PM   #29
V8 VolksRod
Pulled the bug body off today to clean up a few things
[IMG]20160827_141508 by Ben Modified, on Flickr[/IMG]
Ran a tap thru all the body mount threads
[IMG]20160827_145826 by Ben Modified, on Flickr[/IMG]
Applied a thick bead of silicone and bolted down the body.
[IMG]20160827_165610 by Ben Modified, on Flickr[/IMG]
Next, re-install the doors to make sure the the body is square prior to building a roll cage for it.
[IMG]20160827_172445 by Ben Modified, on Flickr[/IMG]
Old August 31st, 2016, 02:31 PM   #30
Looking pretty damn slick !
Old September 1st, 2016, 12:12 PM   #31
V8 VolksRod
Thanks!
Doing the rust repairs on the doors before bolting them back on. The passenger side was not too bad, but the drivers will need new metal at the bottom. I used something called Strong Steel Stik from LPS to patch the better door as well as some pin holes around the side rear windows. I decided to try the product due to the fact the the previous owner had filled every opening in the sheet metal with expanding spray foam. This was the main reason for getting the body sand blasted, but unfortunately, some of the foam remains. So in these areas, to avoid starting a fire or creating toxic fumes, I am filling in with steel stik, instead of welding.
Seems to work well. The large patch at the rear can be welded in.
[IMG]20160831_130859 by Ben Modified, on Flickr[/IMG]
[IMG]20160831_130852 by Ben Modified, on Flickr[/IMG]
[IMG]20160831_150126 by Ben Modified, on Flickr[/IMG]
I will need to make up a patch panel for this area as well as the supporting metal underneath.
[IMG]20160831_150138 by Ben Modified, on Flickr[/IMG]
[IMG]20160831_150243 by Ben Modified, on Flickr[/IMG]
Old September 7th, 2016, 02:11 AM   #32
V8 VolksRod
Started on the inner door replacement sheet metal. Cut out the old and shaped a new piece with a piece of threaded rod and flat stock
[IMG]20160904_130512 by Ben Modified, on Flickr[/IMG]
[IMG]20160906_093837 by Ben Modified, on Flickr[/IMG]
The old piece as a template, the new metal and threaded rod
[IMG]20160906_093839 by Ben Modified, on Flickr[/IMG]
Shaping the new metal
[IMG]20160906_095356 by Ben Modified, on Flickr[/IMG]
[IMG]20160906_095850 by Ben Modified, on Flickr[/IMG]
Making the shape more square like the original
[IMG]20160906_101151 by Ben Modified, on Flickr[/IMG]
[IMG]20160906_101229 by Ben Modified, on Flickr[/IMG]
[IMG]20160906_101331 by Ben Modified, on Flickr[/IMG]
New inner in place
[IMG]20160906_112402 by Ben Modified, on Flickr[/IMG]
[IMG]20160906_112444 by Ben Modified, on Flickr[/IMG]
Every thing welded in. Just need a skim coat of body filler on the outside
[IMG]20160906_173834 by Ben Modified, on Flickr[/IMG]
[IMG]20160906_173923 by Ben Modified, on Flickr[/IMG]
Old September 7th, 2016, 05:56 PM   #33
V8 VolksRod
Door is done
[IMG]20160907_162707 by Ben Modified, on Flickr[/IMG]
Old September 11th, 2016, 09:41 AM   #34
V8 VolksRod
Rust repairs on both doors are complete. Re-installed them this morning
[IMG]20160911_100332 by Ben Modified, on Flickr[/IMG]
Prior to removing the doors, I drilled a small hole thru the hinges, the body and the backing plates to make re-assembly and alignment easier. It worked very well, I was able to re-install the doors by myself with the help of a floor jack and a couple of drill bits. I tightened them down and they shut properly on the first try!
[IMG]20160911_091623 by Ben Modified, on Flickr[/IMG]
[IMG]20160911_120029 by Ben Modified, on Flickr[/IMG]
Old November 17th, 2016, 03:35 AM   #35
V8 VolksRod
Currently replacing all of the brake lines and the master cylinder
[IMG]20161116_154847 by Ben Modified, on Flickr[/IMG]
[IMG]20161116_154905 by Ben Modified, on Flickr[/IMG]
Old November 17th, 2016, 03:04 PM   #36
V8 VolksRod
Made up and installed an additional crossmember today
[IMG]20161117_115715 by Ben Modified, on Flickr[/IMG]
[IMG]20161117_164610 by Ben Modified, on Flickr[/IMG]
Also made a two hour round trip to my nearest Harbor Freight to save $200 in shipping costs on 444 lbs of Tool Boxes. Two 5 ft tall rollaways in a Scion xB
[IMG]20161117_164547 by Ben Modified, on Flickr[/IMG]
[IMG]20161117_164557 by Ben Modified, on Flickr[/IMG]
Old November 18th, 2016, 03:46 AM   #37
It's amazing how much you can cram into an xB isn't it? I've done similar stuff and didn't have to destroy the interior to do it either. ( We used to have 2 2012 xB's)
Old November 18th, 2016, 03:32 PM   #38
V8 VolksRod
Todays load in the xB includes the complete front and rear suspension, brakes, front and rear subframes along with 4 wheels and tires and a mini spare for a 93 Miata. Also a full sized floor jack and 4 jack stands
[IMG]20161118_171450 by Ben Modified, on Flickr[/IMG]
[IMG]20161118_172034 by Ben Modified, on Flickr[/IMG]
I lined the inside with cardboard and stuffed suspension in all the way to the glove compartment.
At one point I had air suspension on the xB and carried a mountain of ceramic tile in it.
Interesting loads also include two full size water heaters
A full size refrigerator. Had to fold both front seat backs all the way down and use the frig box as the seat back.
A wrecked Honda CBR600 Sportbike. The hatch was 2 inches from closing.
Old November 19th, 2016, 10:16 AM   #39
And That was with the little xB... Shoot mine was the larger version... I suspect a tiny bit more room in the 2012 than your first gen Box... But Still they are capable little mchaines no doubt. The later models have a much stronger engine too. (Camry 2.4 engine If I remember right)
Old November 29th, 2016, 04:01 PM   #40
V8 VolksRod
Finished up all the new brake and clutch lines and bled both systems. Used insulation around the lines that are near the headers.
[IMG]20161129_131122 by Ben Modified, on Flickr[/IMG]
Old June 3rd, 2017, 07:37 AM   #41
V8 VolksRod
Progress on the wheel tubs
[IMG]20170602_170753_resized by http://www.BenModified.com
Old June 5th, 2017, 08:45 PM   #42
Amazing
Old February 14th, 2019, 03:40 PM   #43
V8 VolksRod
Finally took the V8 Bug for a short drive..open headers. Good progress on the hood scoop and flamethrower exhaust!
Videos at:
Old February 15th, 2019, 07:51 AM   #44
Square
Square's Avatar
Awesome!
I like the flame thrower
Old February 15th, 2019, 09:20 AM   #45
Looks like she's doing abut 170 just sitting there. Slick looking machine. Reminds me of the old AA Fuel Altered class of the '70s.
Old February 15th, 2019, 02:41 PM   #46
V8 VolksRod
Originally Posted by Square View Post
Awesome!
Thanks!
Old February 15th, 2019, 06:52 PM   #47
flatheadgary
i did something like this a few years ago except i took 10 inches from behind the door and shortened it. also chopped the top. it will be a drag car only so i won't have a few of the problems you have had to overcome. cool car for sure.
Old February 16th, 2019, 09:08 AM   #48
This brings back fond memories of my Fiat Altered from way back when.
Old February 23rd, 2019, 02:39 AM   #49
V8 VolksRod
If you have some photos, please post here!! I would love to see them.
Old February 23rd, 2019, 02:40 AM   #50
V8 VolksRod
Latest updates are on youtube now.
https://www.youtube.com/watch?v=45Wlb49ZYSI
