Members: 17,580
Threads: 32,323
Total Online: 458
Newest Member: Starfish1991
Old February 16th, 2017, 10:32 AM   #26
Default Re: 67' Shenanigans
Well, maybe in Canada. You don't have to worry that much since you never get down to the pavement under 24' of ice...
Old February 21st, 2017, 05:57 AM   #27
kustomkreep86
kustomkreep86's Avatar
Yeah for the most part we just stick some skis on the front and giver...haha
Build...Break...Fix...Repeat
kustomkreep86 is online now   Reply With Quote
Old March 24th, 2017, 04:47 PM   #28
BadAttitude
BadAttitude's Avatar
Holy cow! Been while much? I'm not sure if it was for everyone or just me but the site wouldnt load just getting error 403's. I had to attend a few AircooledsAnonymous just from the withdrawals. Just finished moving the majority of my s*** into the new garage and most my work has been focused on getting my bus back on to the road. Also changed Spark plugs and wires on the Turbo 1915cc. Runs moocho better now. Eventually going into the little 67' . Glad to be back though!
"We'll just make a flange and zdus it back on!"
BadAttitude is offline   Reply With Quote
Old March 28th, 2017, 11:51 AM   #29
theredbarn
theredbarn's Avatar
When I brought my 67 home, it was that low. Was nerve wracking to drive. Handled OK but you never knew what it was going to scrape on. I raised it up a notch in the back and I have about 2" under the beam with a skid plate. I still ring the plate occasionally and the exhaust scrapes once in a while and speed bumps frequently give me issues... but cruising down the crappie roads is no longer an issue.
Old March 29th, 2017, 05:34 PM   #30
BadAttitude
I have about an inch of beam clearance which is why a pie cut is on the to-do, I'm not so much worried about the front apron because the PO bumped into a few things and screwed it up. Where did you get your skid plate, pics?
Old March 30th, 2017, 02:51 PM   #31
70 Bug Mid Engine
70 Bug Mid Engine's Avatar
Geez that thing is low! I dont know how some of you guys do it. I have mine set at 5" ride height (I dont have a beam to measure from but 5" is the lowest point) and can barely make it out the driveway. Cant imagine going any lower then that.
1970 Bug - For some reason there is a radiator up front...
70 Bug Mid Engine is offline   Reply With Quote
Old March 30th, 2017, 07:24 PM   #32
BadAttitude
When I lowered It just had to accept that it was gonna scrape a ton, when I go on a cruise I don't ever go further than 10 miles so I have an idea in my head of where all the large bumps are so I can avoid them before its to late. One day I went down a new road and there was one of those dips where it shadows just right and you cant even tell its there, long story longer it snagged the lower adjusted bolt and dropped it even more! Ill never make that mistake ever again
Old March 31st, 2017, 07:32 AM   #33
Lowest point on my Single Cab is the bottom of the T-98 tranny at just 9 1/4" clearance. I laugh at bot's dots & speed bumps, though I do slow for the latter.
Old April 4th, 2017, 05:44 PM   #34
Speed bumps are the devil. My F250 4x4 doesn't have a problem getting over them, but man do it bounce. I have no choice but to go across them to get in or out of the trailer park.
Old April 4th, 2017, 07:00 PM   #35
Try tapping the brakes just before hitting the 'bump', then go over it.
Old April 6th, 2017, 11:19 AM   #36
theredbarn
theredbarn's Avatar
Bolts on using the beam mounting bolts...
https://www.pandraggers.com/product-...ers-skid-plate
Old April 7th, 2017, 10:07 PM   #37
I used to have a 64 LeSabre. It was stock, but I had 235r60s on it, so it was a bit low. It has what I can only describe as metal mud flaps behind the front wheel openings. They were like 3" off the deck. It drove like riding the couch through a sea of mashed potatoes. When going over speed bumps, I'd have to stop as soon as the fronts cleared. Let the suspension settle, then go again. If not, it'd hit those flap things or my Flowmasters every time.
Old April 30th, 2017, 12:33 PM   #38
BadAttitude
Hmm looks pretty cool, do you have any problems with the bottom adjuster hitting from being unprotected?
Old June 13th, 2017, 04:35 PM   #39
BadAttitude
I will try my best to update this as frequently as possible but for some reason every once in awhile I will get an error 403 when trying to load up the site and it will stay that way for a week off an on. Anyway, been slowly working on the Turbo motor for the 67. As of now it's a 1915cc with a Holley 2bbl, Musa Turbo and unfortunately a stock trans ( on the list ) Right now I'm battling the carb being too rich. The PO had the builders set up the engine to be best on the strip, so im undoing all the whackie stuff they did. One of the problems was the carb was set up to run the best at full throttle, I boost referenced the carb (jb weld to the rescue!) The jets were at 85 and I dropped them to 72 still running rich. At the moment I'm going to call the shop who built it to figure out what to set the valves at, also trying to figure out timing with the Dist that is on it then adjust the float and I'll see how it runs then.
Noob Note: I'm still figuring out the pictures so bare with me and please tell me if they aren't working
Old June 13th, 2017, 06:00 PM   #40
BadAttitude
Kind of cool, not to long ago I got featured in Roadkill magazine! Whoop whoop
Old June 14th, 2017, 07:31 AM   #41
Damn, you be famous!
Old September 26th, 2018, 08:08 PM   #42
BadAttitude
Talking Re: 67' Shenanigans
Uh wow, long time no see! I apologize for not continually updating but the forum doesn't always work. I do post on the TheSamba frequently. I did get the 1915T into the lil 67. I friend of mine ran an identical setup and made 240-250 to the wheels
And YES I know the "hater pipe" is tall but I did need some length for my O2 sensor
Old September 26th, 2018, 09:12 PM   #43
It looks tall 'cause the bug is sooo low. Good the see you're still going with the Volksrod. Over 200 some horses at the rear wheel?
Old September 27th, 2018, 03:07 AM   #44
How does the power feel on the road? Looks awesome.
Old September 29th, 2018, 02:53 PM   #45
BadAttitude
Thanks man, it feels fantastic. It really is night and day compared to N/A. It has great torque down low and then once you start to get up on boost in 3rd it's like a bat outta hell. Unfortunatley I've never had it on full boost (10lbs) in 4th gear. It's just dang scary and I worry I'll detonate the tranny. Eventually I'd like to get 3rd4th welded if I can't get anything else done to it. Here soon this winter I am planning to pull the motor and get the case re-sealed, new rings, bearings, hopefully a 69mm counter weighted crank and some ratio rockers. In the meantime I am going to build a 1776 that I got free from a buddy with a Mitsubishi generator turbo. The thing is tiny so it should spool to the moon
Old September 30th, 2018, 06:09 AM   #46
Certainly fills the engine bay nicely. Got to be a riot to drive.
