Members: 17,576
Threads: 32,321
Total Online: 590
Newest Member: Wozza
- by bigguy
Old November 15th, 2004, 07:55 PM   #1
cdubvdub
so i searched and i couldnt find what i was looking for. What kind of bench seats are you guys using? I really like the was they look and am going to be looking into it.
follow my instagram @cdubvw
cdubvdub is offline
Old November 15th, 2004, 07:58 PM   #2
gowjobs
gowjobs's Avatar
Seems like I remember one or two starting with older minitruck benches, but I'll bet you could find plenty of removable third-row benches out of minivans available for a song, and they're narrow enough, since they're designed to fit between the wheelwells.
-Dave
"When worse comes to worst...
..we're screwed"
gowjobs is offline
Old November 15th, 2004, 09:01 PM   #3
'77 Toyota p/u [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
$35 at the wrecking yard. Narrowed about 1 1/2" with a sledge hammer.
(still won't be able to run door panels though...)
[attachmentid=2675]
Steve is offline
Old November 16th, 2004, 03:29 AM   #4
356 optional bench seats [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
It'll cost you though [img]style_emoticons/<#EMO_DIR#>/funny.gif[/img] Another way it to take the two stock seats and connect them together (weld frames in between and re- upholster)
Nick is offline
Old November 16th, 2004, 03:31 AM   #5
dodge caravan 3rd row seat....even has armrests and seatbelts built it
vwfanatic is offline
Old November 16th, 2004, 04:05 AM   #6
Griznant
Griznant's Avatar
I really wanted to do a bench seat in mine, but now that I actually have the roof on, and the floor channeled, I've discovered that this is no longer possible. Basically, I'll end up sitting on the floor, and the tunnel will be damned near high enough to be a center console! [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
So, the bench seat is out. I don't want to copy Walt's kick-ass bomber seats, so I need to come up with something. Even a milk crate is too high! [img]style_emoticons/<#EMO_DIR#>/cool.gif[/img]
Griznant is offline
Old November 16th, 2004, 06:44 AM   #7
Top_Fuel_Thomas
i was just going to use a stock bug back seat somewhere in the middle of the car, will this be too wide then?
im shortening my rear quarter pannels so will have no back seats so it wont need to recline or anything.
TFTom
<span style=\'color:orange\'></div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE </td></tr><tr><td id=\'QUOTE\'>I'll kill you you sick english FREAK!</td></tr></table><div class=\'signature\'> alltypesvw</span>
Top_Fuel_Thomas is offline
Old November 16th, 2004, 10:59 AM   #8
Ya, bench seats were in my plans until I channelled the body. Would look stupid having the tunnel 2 feet above the mddle of the benchseat.
Nick is offline
Old November 16th, 2004, 01:47 PM   #9
cdubvdub
TFTom
yah i tried that like a week ago. I'm sure you could modify it to fit but it is too wide stock.
cdubvdub is offline
Old November 16th, 2004, 02:15 PM   #10
dayzwalker
dayzwalker's Avatar
Well, all this talk about bench seats has had me thinking. I didn't really know how the frame of a stock vw back seat was put together much before today. I had the one that I pulled out of my chop top, and I just shoved it in the back shed under some boxes. Reading this thread got me thinking about converting it into a front bench seat...I knew it could be done. So I decided since I wasn't doing anything today before work, I'd start buidling one.
I took a bunch of measurments and the stock bench is definately too wide to fit in the front without cutting a good sized section out of the middle of it. The stock bench is 51" wide and the longest you can make it, with the rails sitting on the heater channels is 46". I ended up cutting out a 7" section of the middle of the bench, so now its 44" long. Its sits perfectly just inside the heater channels. You also have to notch the springs to get them to fit around the tunnel.
I haven't gotten to welding any of it together...mainly cause I don't have one. [img]style_emoticons/<#EMO_DIR#>/dry.gif[/img] ...but also cause there needs to be some boxed reinforcemts drawn up for where the bench rolls around the tunnel. Plus, what the heck am I gonna do with my e-brake. What did the rest of you guys do??? [img]style_emoticons/<#EMO_DIR#>/Idunno.gif[/img] [img]style_emoticons/<#EMO_DIR#>/confused.gif[/img]
This is just the seat bottom so far...I haven't even started to rip apart the seat backing yet. It looks like it can be cut down just the same though. I would also like to keep the tilt back feature. I was thinking of making a bracket coming off the b-pillar.
...back to the garage [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
Well, here's what I got so far...it's a start. [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
BUILDING A BENCH SEAT
A Fetivus for the Rest-iv-us
dayzwalker is offline
Old November 16th, 2004, 02:49 PM   #11
Justin, Cliff and Steve have both relocated their ebrakes to the side of the tunnel next to the shifter. You know where you can get that frame welded up...
hotrodheb is offline
Old November 16th, 2004, 02:57 PM   #12
JBUG
JBUG's Avatar
Well If anyone remembers juschopits bug we just used a middle seat out of a baywindow bus it fits perfect we even welded on the sliders.
10 kinds of nasty!!
JBUG is offline
Old November 16th, 2004, 02:59 PM   #13
Did you guys relocate the ebrake or just eliminate it?
Old November 16th, 2004, 04:10 PM   #14
crack monkey
crack monkey's Avatar
hows he doing anyway?
crack monkey is offline
Old November 17th, 2004, 06:37 AM   #15
alltypesvw
alltypesvw's Avatar
Originally posted by hotrodheb+Nov 16 2004, 06:59 PM--><div class='quotetop'>QUOTE(hotrodheb @ Nov 16 2004, 06:59 PM)</div><div class='quotemain'><!--QuoteBegin-JBUG@Nov 16 2004, 03:57 PM
[/b][/quote]
I think they just went ahead and mounted it on the dash [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
alltypesvw is offline
Old November 17th, 2004, 09:54 AM   #16
Top_Fuel_Thomas
i was going to use a mechanical line lock, search for line locks i already posted details of it. That way not only do you get a cool seat, you can stop your car on hills and not get leg-ache and also you can do burnouts!
Thanks for the pics dayz, be our guineepig for us!
TFTom
Old November 17th, 2004, 11:07 AM   #17
dayzwalker
dayzwalker's Avatar
I cut up and fit the passenger side seat as well yesterday afternoon. Here is the whole seat bottom just suitting in there for a test fit. Looks like its gonna fit pretty well...maybe might even keep the ebrake in its stock location. I am thinking of just building the seat around it and cutting a little notch in it for the handle to lay down into. Today I'ma go cut up the seat back, I'll post pics as soon as I can. [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
Old November 17th, 2004, 02:10 PM   #18
Hey Dayz, whenever you finish your seat I'd be willing to put that up in my How To article section on my site if you're willing [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
Nick is offline
Old November 17th, 2004, 07:05 PM   #19
dayzwalker
dayzwalker's Avatar
That'd be great Nick! [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img] When I'm all done I'll put together an easy to read step by step of how everything was done.
Today I did a little more work on the seat bottom figuring out how I am going to be able to keep the ebrake in its stock location. I dunno, but when I looked at the bench sitting where it was and picturing a small notch in it for the ebrake to come though with a beauty boot slipped over it, I really liked how I saw it in my head. I cut out some cardboard templates for the sheetmetal to fit around the ebrake. They will be welded straight onto the ends of the springs themselves. This will give a nice flat surface for the upholstery guy to mount that padding and fabric to. I'll take some pics tomorrow when I work on the seat back. [img]style_emoticons/<#EMO_DIR#>/thumbsup.gif[/img]
Old November 18th, 2004, 09:18 AM   #20
Justin, is it just me, or does the seat angle down towards the front? If so, are you planning on having the front just built up with foam?
Oh and we need to get together and do up a long shifter for your car!
Old November 18th, 2004, 05:35 PM   #21
railroad_foreman69
gonna use a dodge caravan seat (the narrowest one ) already has attached seatbelts and the brackets will be easy to adapt...... [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img] [img]style_emoticons/<#EMO_DIR#>/Dancing.gif[/img]
railroad_foreman69 is offline
Old November 19th, 2004, 10:27 AM   #22
60ragtop
60ragtop's Avatar
I used a rear seat from an old CJ5 Jeep. Had to widen it about 12" to fit the bug
60ragtop is offline
Old November 19th, 2004, 03:41 PM   #23
My model A truck I had when I was a teenager had a school bus seat in it [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
bugdust is offline
