Threads: 32,385
Total Online: 655
Old December 22nd, 2019, 02:10 PM   #1
Justin726
Default Fabshop104 Steering Extension Kit?
I bought a 10" extension along with the steering kit from Doug. Has anyone installed the steering extension/support kit that he sells? Before I start hacking a guessing, are there any pointers where to start at? Just by mocking things up it looks like maybe cutting the crushable section out of the stocking shaft and welding it back together might get me close. The car is a '68 if that matters at all.
I searched around and haven't found much info. If all else fails, I'll try getting ahold of Doug. I know he's busy so I was trying to avoid bugging him.
Justin726 is offline   Reply With Quote
Old December 23rd, 2019, 04:53 AM   #2
Default Re: Fabshop104 Steering Extension Kit?
I can't speak 100% about Doug's kit, but When Rob installed my 10" TinBeater extension, we DID cut the crush section out of the shaft.
Old December 28th, 2019, 12:04 PM   #3
Justin726
Thanks.
I'm guessing it was engineered in a specific way. Kinda makes sense. I'm still waiting to get my new front beam, then the final fit can be made.
Old December 28th, 2019, 02:11 PM   #4
Just curious, but what kind of beam are you getting? Sounds like you’ve got a pretty cool project going.
Old December 28th, 2019, 02:46 PM   #5
Justin726
Nothing too crazy. It's a great driving '68 that I planned to put a 10" extension on. Has some pretty decent patina to give it a little character.
Ordered the extension and steering kit from Doug. As I was waiting for those I started tearing things down getting ready to cut sheetmetal and do what I could in the meantime. I pulled the stock beam off planning on cutting and putting adjusters on it, in addition to the 1.5" drop spindles that are already there, but I ran into a little more rust on the beam than what I was happy using so I just ordered a stock replacement from Doug as well. It will come with adjusters already installed. Probably starting off with doing 3" drop plates out back on the swing axles.
Has been a fun project so far for sure. Waiting on parts kinda sucks, but it's part of it I guess.
Old December 28th, 2019, 07:06 PM   #6
Yup, but while you’re waiting you can go over ideas ‘n such. 👍
Old December 30th, 2019, 03:52 PM   #7
If you bought from FabShop104, that's Lawrence. Just shoot him a message, he'll help when he he has time.
There used to be a ton of info on this site, but the update years ago dicked up all the pics.
Old January 7th, 2020, 11:54 AM   #8
tinbeater
tinbeater's Avatar
Not sure how Doug handles his kits but with mine you had to cut down the steering shaft in order to get the geometry correct. IIRC it was 7 inches cut out, then sleeved and the end welded back on in order to retain the stock steering stub flange.
Old January 8th, 2020, 02:57 AM   #9
holy shit! you're still here!
haha, yeah I'm pretty sure that's what Rob did when he was installing mine back in 2007..
