Threads: 32,384
Total Online: 568
Old December 31st, 2019, 03:25 AM   #1
sallyandsean
Default 034 distributor set up
Just fit an 034 and timed it to 32į at 3500rmp with vacuum pipe blocked off. After attaching vacuum pipe there is no further advance from 32į and I still have a horrible flat spot so unable to drive. I can see the vacuum seems to be in a different position to others and no1 is straight back to the fan when lining with the notch. What am I doing wrong? Pictures show position and vacuum hook up.
sallyandsean is offline   Reply With Quote
Old January 1st, 2020, 08:38 PM   #2
Default Re: 034 distributor set up
Itís been a really long time since Iíve worked on a VW flat four. So I donít want to lead you in the wrong direction. I checked out a site www.aircooledvwlove.com that might help you out. I hope this helps.
Old January 8th, 2020, 03:36 AM   #3
sallyandsean
After several hours of adjusting mixture, squirt and timing, this is where it's at.
https://youtu.be/9SLOP_x85jI
Old January 8th, 2020, 02:36 PM   #4
marnat3
marnat3's Avatar
Sounds great!
marnat3 is online now   Reply With Quote
Old January 8th, 2020, 07:15 PM   #5
Engine sounds like your time was wisely invested. 👍👍Whatís next?
Old January 9th, 2020, 02:42 AM   #6
sallyandsean
Finish safari screen
Old January 9th, 2020, 11:18 AM   #7
Iíve been running Safarisí on my single cab for several years now. And added a unit to the rear cab window two summers ago. They are great in traffic and really Ďcoolí on hot days. 😃😃
Old January 9th, 2020, 12:42 PM   #8
sallyandsean
This is where I'm at with the home made kit.
https://youtu.be/yaFAb48M2Pw
Old January 9th, 2020, 05:24 PM   #9
Looks slick! Besides being practical, a mod like that really makes your ride stand out.
Old January 9th, 2020, 10:18 PM   #10
sallyandsean
Thanks buddy
