Threads: 32,384
Total Online: 564
Old May 12th, 2020, 04:07 AM   #26
Default Re: I ainít dead yet, making a truck.
Kinda has that "Smart car for 2" look...
Old May 12th, 2020, 11:04 AM   #27
I got sick of trying to move my cart around so I found some scrap.
I trimmed the fat on the window.
Old May 13th, 2020, 11:20 AM   #28
Old May 14th, 2020, 04:55 AM   #29
Coming along nicely.
Old May 14th, 2020, 10:13 AM   #30
Getting closer and closer.
I decided to see if I could connect the drip rails by doing a 7 inch cut on each side to allow the metal to be shaped and tacked. I think this is going to turn out nicely. Never seen a bug truck done this way.
Probably because this takes a bit more effort than just lobbing off the back and calling it a day.
Old May 14th, 2020, 10:36 AM   #31
Great job with the blending of the lines. I love the Ďwrap aroundí effect.
Old May 14th, 2020, 01:30 PM   #32
Same here. Itís much more complete look in my eyes than the typical lob off the back.
Progress until the little piece I cut out for the passenger side cab corner vanished.
Old May 14th, 2020, 03:12 PM   #33
junkophile
DrHax,
Do yourself a favor and cover the inside and outside of that window with something (cardboard at least).
Welding spatter will ruin the glass quick and it will ruin your day (don't ask me how I know).
I don't have ADD, it's just that.... OH look, a bunny rabbit.
I like little shiny things.
It's not how fast you cut, it how well you cut fast.
junkophile is offline   Reply With Quote
Old May 17th, 2020, 12:46 PM   #34
Projects on hold I fractured my nose..
Hereís my progress before this.
I also discovered this lovely repair under a patch of bondo.
So Iím a bit fucked up right now.
Old May 17th, 2020, 04:12 PM   #35
marnat3
marnat3's Avatar
How the hell???
marnat3 is online now   Reply With Quote
Old May 17th, 2020, 06:34 PM   #36
I believe the question youíre asking is actually ĎWhiskey Tango Foxtrot Oscar?í
Old May 17th, 2020, 10:33 PM   #37
Originally Posted by marnat3 View Post
How the hell???
I went for a walk on the property and because I have no balance and need a cane when I found a hole in the ground I fell hard. There was a fucking rock hidden in the grass. My family heard the Wilhelm scream and came out to investigate. I got fucked up real good.
Yeaaaah so I got to go to the ER be rushed to a hospital 45 minutes away via ambulance for surgery bleed for 10 hours straight only to be told at 11:2XPM that they couldnít do anything because of the swelling.
As sad as it is I lucked the fuck out. It was only my nose. Not my jaw or the rest of my face but yeah itís all fucked up.
Oh I also swapped out the 6 volt solenoid on the starter for a 12 volt one. But can somebody explain to me how the hell a solenoid costs 60$ but a WHOLE remanufactured 12 volt starter costs 38$? So now I have a 6 volt starter with a 12 volt solenoid and I have a 12 volt starter with a 6 volt solenoid
Old May 18th, 2020, 06:44 AM   #38
Ouch! Well at least you still have a VolksRod to mess with and your sense of humor is intact. Plus the starter/solenoid 12 and 6 volt combo has me completely confused. Which these days isnít that difficult. Maybe switch to a 9 volt system?
Old May 18th, 2020, 02:39 PM   #39
The 12 with a 6 volt solenoid is mainly so I can store the parts easier and not lose anything. The main thing I wanted was a 12 volt solenoid on a 6 volt starter that way the gear would work with the flywheel.
Reasoning is you can use a 6 volt solenoid but it has a higher chance of grinding teeth because things are really spinning fast.
Oh my engine test stand half ring arrived with its 12 and 6 volt bushing
Adapters.
It was the easiest install ever. So easy Iím paranoid and terrified that something isnít right. It was toooo easy. Working with cars is never supposed to be this easy? What is this madness!?
Old May 19th, 2020, 08:17 AM   #40
Maybe Ďthings being easy nowí is an attempt to make up for past Ďpains in the buttí parts of projects. 🤔🤔😲😲😀😀
Old May 19th, 2020, 05:30 PM   #41
Or maybe Iíve spilt enough blood via my face so the car gods are pleased with the blood sacrifice.
Right now Iím trying to work out the wiring for a test engine stand. I just need to get a proper switch and a decent ground.
Old May 19th, 2020, 06:32 PM   #42
So the Ďcar godsí likely wonít insist you keep your Ďnose to the grindstone.í
Old May 20th, 2020, 08:31 AM   #43
No work will be done today as Iím going back to the cities to get my nose looked at. Iím getting a clear fluid constantly leaking from my left nostril so thatís alarming and since I canít breathe through my nose and have to use my mouth my throat really hurts, honestly Iím a bit worried about infection at this rate, even if Iím not leaking CSP fluid ( or what ever itís called.)
Donít crack your face open. 0/10 would not recommend. Canít see this catching on with the kids.
Old May 20th, 2020, 09:03 AM   #44
amrcnbadaz
amrcnbadaz's Avatar
I wouldn't be so sure of that. That do some pretty dumb shit now-a-days.
ie:TidePod challenge, outlet challenge, the choking game, finding new ways to assault their nards, etc, etc. If you had got a video of it happening to post on youtube, the copycats would be everywhere!
QUOTE Steve Jan 26, 2008
Old May 20th, 2020, 09:04 AM   #45
Take care of yourself and let us know how itís going.
Old May 20th, 2020, 10:20 AM   #46
I swear civic departments get their rocks off by tearing up one ways in front of hospitals. Thereís some civil engineer rubbing themselves knowing theyíre maximising grief and hardship for the dumb poor fucks who have the stupid idea of being able to get to a hospital with ease.
Old May 21st, 2020, 07:45 AM   #47
This is a nightmare. The hospital is forcing me to do many things. So the 27th is my surgery I need to come in the day before for stupid fucking covid-19 testing. Keep in mind I live 55 minutes away from that hospital and I canít drive so my family needs to drive me there. Theyíve already driven down there yesterday for me for the assessment. I canít breathe through my fucking nose and the only place I could have caught this stupid fucking virus is at that hospital as Iíve been inthe rural countryside for the last past 16 months unable to leave my house or do much of anything.
Honestly if this crap keeps up I might not be able to finish my car because Iíll be bankrupted as I have no source of income because Iím disabled and applying for ssdi
Old May 21st, 2020, 07:20 PM   #48
When my heart started Ďacting up a few years back, a doctor at the VA Clinic gave me a breathing exercise to keep me calm. I kept at it and eventually made the Ďproblem literally go away.
So, get comfortable, breath in slowly through your mouth for five seconds. Hold your breath for five seconds, then breath out for five. Hold again for five seconds. Then repeat. Iíd usually do this eight to ten times. I generally tried to sort of empty my mind as I did this.
Youíre young and stronger than you may think. Youíll get through this.
Old May 21st, 2020, 09:16 PM   #49
I havenít died yet. I know Iíll get through this. Iím just starting to feel like a sea world dolphin. Watch Dr.Hax the amazing cripple jump through all of these hoops!
Good news though I was able to wire up the postive side of my engine test stand, and I found an affordable windshield for the car so thatís coming in the mail.
Hopefully I can go to the auto parts store and pick up the switches and battery grounding strap I need to finish the test bench then I can see if the engine will start up. Only thing Iím uncertain about is the coil, however I found out the local tractor supply sells coils for 24$ also when it comes time to paint it I have figured out the colour I want. Itís 1 gallon of tractor paint mixed with 1 quart of John deer green. This creates a very nice sea foam green which is pretty close to the 1966 Bahamas blue colour. And it should only cost 60$
Oh I found a picture of this mixture from the HAMB
