Total Online: 613
Old January 7th, 2019, 09:31 AM   #101
Default Re: 74 Super with Longitudinal Acura 3.2 V6
With the 'hatch' you'd keep the VW profile and still have good access to the engine. The bulkhead, even with a rear window would keep the noise way down.
Old January 25th, 2019, 08:59 AM   #102
PJLOval
PJLOval's Avatar
Wow! Just found this thread. Haven’t been on here in a long time. I’m also building a mid-engine beetle but using Passat/Audi 1.8t and 5 speed. Its PFM in the intro build section. I like the way your setup is working out. Will be reading all the way through this and checking out the tread on the samba!
Old April 16th, 2019, 06:47 PM   #103
carwhisperer
Bought $200 worth of turbo stuff from ebay sellers and started putting together a system. There are other parts that i should be working on but this sounded more fun
hey google flip a coin
Old April 16th, 2019, 07:03 PM   #104
carwhisperer
Thanks! I read through your thread. Am I right in saying you've been at it for 11 years? Then again, there are no rules for this stuff and I read you've finished other projects in the mean time.
I couldn't seem to post in your thread but your project looks really cool
Old April 17th, 2019, 11:00 AM   #105
And besides being a fun part of the project, tinkering on the turbo should likely 'boost' your enthusiasm.
Old September 8th, 2019, 06:23 PM   #106
carwhisperer
The car made noise today. I put a cheap eBay fuel pump in the tank with a modified Honda drop in. I ran 5/16 plastic fuel line up and back for supply and return. I hooked up the ecu and cranked it. Iím getting fuel to the rail but I think the injectors arenít injecting. I could get it to sputter on starting fluid so the ecu is doing something apparently. Charging the battery now for more messing around when I have time.
Old September 8th, 2019, 06:23 PM   #107
carwhisperer
Oh yah I bought a couple 911/996 C4s also.
Old September 11th, 2019, 06:23 AM   #108
Looks like you got a co-driver as well !
Old September 11th, 2019, 01:55 PM   #109
carwhisperer
haha not exactly
Old September 14th, 2019, 06:51 PM   #110
carwhisperer
Started the engine today. I chased some grounds and power wires and it fired up.
https://www.facebook.com/brian.roth....513197156/?t=0
C32A Powered Beetle Starts first time
Old September 15th, 2019, 07:08 PM   #111
carwhisperer
I made some coolant lines today out of 1Ē EMT galvanized steel conduit. I researched the way Subie guys do it, thinking running it through the heater channel would be the elegant approach. It turns out thatís nearly impossible and you really hack up the channels. So I ran it underneath like those guys do
Old September 28th, 2019, 07:03 PM   #112
carwhisperer
I mounted an early 2000s Accord AC condenser and hooked up all the coolant lines. Tomorrow I hope to put together the parking brake cables and start working on the throttle cable. I bought a 3700mm cable for a bus and a peddle cluster rebuild kit. I plan to add some cable housing left over from the parking brake.
free baby name generator online
Old September 29th, 2019, 10:21 AM   #113
speedbug78
speedbug78's Avatar
Looking good! Not sure if you already have them, but I suggest adding some bleed fittings to the coolant lines back by the engine to help get the air out.
Note to self: embedding images from google drive needs the following url, https://drive.google.com/uc?export=view&id=[imageID]
speedbug78 is offline   Reply With Quote
Old October 6th, 2019, 05:46 PM   #114
carwhisperer
I appreciate that and I was thinking about it. Acura put a bleeder nipple by the thermostat housing. Hopefully that will be enough. I bought the longest Transporter throttle cable I could find that had the right pedal end, rebuilt the pedal cluster, hooked up the parking brake (required a little welding to make the cable ends compatible with the 944 parking brake), used pieces of the leftover handbrake cable housing for the lengthened throttle cable, painted the rear calipers and put in new pads. The pedal doesnít move as smoothly as Iíd like though.
what is a baby panda called
Old October 13th, 2019, 07:38 AM   #115
carwhisperer
I resurfaced the 928 front rotors and made new hard lines to connect the front Brembos to the super beetle hoses. I filled the reservoir with brake fluid and started bleeding. It took over an hour but I was astonished to find I actually had a somewhat firm pedal when I was done. I wouldnít be surprised if the master cylinder is original, as so many other things are on this low mileage chassis. Iím super excited about the monster brakes on this thing and I canít wait to outbrake a 930 at the end of the Mulsane straight 😃
Old October 13th, 2019, 09:12 AM   #116
Great job and those wheels will really show Ďem off.👍👍
Old October 15th, 2019, 05:55 AM   #117
Bit by bit, this one just keeps getting better and better.
Old October 16th, 2019, 07:39 PM   #118
This is starting to get better and better
Old December 7th, 2019, 07:25 PM   #119
carwhisperer
I bought this genuine wooden steering wheel a year ago for $10. New never mounted. I had an aftermarket hub laying around with the same splines and bolt pattern but the wheel didnít have any dish and hit the turn signal switch. So I bought some 1/4 ID copper tube and made these spacers. I used some Allen bolts I had laying around and painted the heads body color. I think it looks a little better in person. What do you think?
Old December 8th, 2019, 09:25 AM   #120
Basic hot rod engineering ! Good job. You do what it takes sometimes just to make things work.
Old December 8th, 2019, 08:25 PM   #121
Only concern is torsional torque.
65 Sunroof Notchback
Old December 9th, 2019, 04:51 AM   #122
This.
I love the craftsmanship and making something work, but i'd be worried about having to do a hard turn and twisting all those pipes..
Also, the wood wheels look really cool, but if you drive in the summer time, get a cover. It's no fun when you're cruising along and suddenly skin touches that metal that's sandwiched between the wood.. lol, i learned that one the hard way.. ;)
Old December 10th, 2019, 07:50 PM   #123
carwhisperer
I agree with the torsional torque concern. However, I don't think I'll likely reach the torque limit. The 1/4 bolts are grade 8+. I don't think the copper spacers are doing too much. I suppose it will be one of the things I kind of get the feeling of during beta testing of the car.
But I'd hate to have the wheel come off in my hand when I'm trying to outbrake a 917K at the end of Mulsanne:)
I think the appearance in the photos do not do it justice. In the metal it looks a lot better I think. I was going for a jewelry/steam punk look. Maybe I'll paint the bolt heads black instead of orange. If I do, black will be the new orange, haha. Once the interior is cleaned up more it will look better too I think.
Old December 10th, 2019, 09:19 PM   #124
Park next to a curb, turn the wheel so that the tire makes contact, pull hard and see what happens. Iíd guess all will be fine.👍👍 Thatís what I did when I swapped a Ďwood steering wheel w/adapter into my Ď47 Ford coupe back in the late Ď60s.
Old December 11th, 2019, 11:45 AM   #125
Almost forgot. I like the subtly of the orange.🙄😁
