Threads: 32,399
Total Online: 702
Old September 8th, 2020, 01:04 PM   #1
Default Manual tire changer 5 wide adapter?
Iíve looked around and thereís very little information on this. So Iím asking you lot if you have any ideas.
Yes I got a manual tire changer and bubble balancer because the local places refused to mount tires on the vw wheels due to them not being stock.
So yeah. I need to make an adapter Iím thinking about getting some rebar some grade 8 nuts and one of those flat black iron pipe mountings flanges You know the ones with the 4 bolt holes and welding up an adapter
Apparently such adapters existed during the 1960ís and 70ís but we ainít in those times anymore!
Not unless one of you pack rats has one them hanging on the wall
Old September 8th, 2020, 02:20 PM   #2
vinayak
vinayak's Avatar
Default Re: Manual tire changer 5 wide adapter?
https://www.jbugs.com/product/9506.html?rrec=true].
What about a Wide 5 adapter?
Responding to that email does not magically take your response, sign into the forum for you and miraculously place your message into the recipients PM inbox. Nor does it magically place your response into a thread you have subscribed to on the Cutting Board, etc.
vinayak is offline   Reply With Quote
Old September 8th, 2020, 02:36 PM   #3
Youíre talking about the Ďlate 4 lug to early Ďwide 5?
Old September 9th, 2020, 01:44 AM   #4
Not for use on an actual car, but on a machine. Iím uncertain if those adapters wouldnít be a weak link when changing a tire. For some reason I can just see them bending.
I may just go make what I have in mind. Iíll post pictures of it when Iím done
Old September 9th, 2020, 08:16 AM   #5
Originally Posted by vinayak View Post
I would see if you can just buy one of these, it's just like what they used years ago when I changed tires, except it didn't bolt onto the wheel
Old September 11th, 2020, 04:36 AM   #6
Maybe something like this ? https://www.thesamba.com/vw/classifi...php?id=2316556
Old September 13th, 2020, 11:44 AM   #7
I have a set of 13-1.50 nuts coming in the mail Iím going to be making so something. I know itís probably silly but I just want that satisfaction!
Old September 14th, 2020, 07:35 AM   #8
Machine an old brake drum to fit your needs.
Old September 14th, 2020, 08:54 AM   #9
Good idea here.....
Old September 14th, 2020, 07:46 PM   #10
First idea I had... but I donít have spare brake drums.
Instead I got my 13-1.50 nuts a bunch of metal and One of those black iron pipe flange things you know the one with the large 4 holes.
Yeah after a bit of welding it works! Looks like a drunken 1980ís mini camaro wheel but it works.
Nowhere near perfect could have gone better but at this point I donít care.
Old September 15th, 2020, 07:35 AM   #11
Not perfect, but works.🤔 Sounds like most of my projects!😃😃
Old September 15th, 2020, 08:02 AM   #12
As long as it works
Old September 15th, 2020, 08:27 AM   #13
Iím sure he'll Ďworkí it out. 😁😁
Old September 15th, 2020, 03:00 PM   #14
Hereís some pictures it worked great.
Old September 15th, 2020, 07:02 PM   #15
Nice job!
Old September 16th, 2020, 06:37 AM   #16
That looks nice
Old September 16th, 2020, 02:58 PM   #17
I had an old cement slab behind my garage that I bolted my HF tire changer to. Makes a huge difference. Not sure what Iím doing at my new house. The problem with owning a tire changer is you end up with old tires.
Old September 20th, 2020, 02:43 PM   #18
Here's mine, and yes, it's mounted on a granite gravemarker. Just a regular VW 4 lug to wide 5 adapter.
Sent from my SM-G975U using Tapatalk
mkparker is online now   Reply With Quote
