Threads: 32,423
Total Online: 202
- by jorez
Old November 1st, 2017, 04:21 PM   #5951
You mean the front end? I'll just hit up Heidt's or Speedway for a kit. It's under $2k.
Old November 2nd, 2017, 12:42 PM   #5952
Yup that's what I was meaning, back when I started working on my V8 Bug I wanted to use a Mustang suspension on it, I left my phone number at one of the junkyards near by to call me when they got one in, hell that was 10 years ago, he said he has other guys ahead of me but if I got there first I could have it, he also said they are coming in fewer and farther between, I about fell over when he said $1000, by the time you replace the brake parts and everything else you can just about buy a new one, then my son's S10 got ass ended so I used the front suspension from it
Speaking about that Bug, I almost have my Eldorado cleaned off so I can trade places with them, my brother is moving across the street from his house, he has the factory headers from his Mustang GT in his garage so I will finally get it, I just need to bolt them on and fab the firewall, then finish welding everything, I'm gonna try to do a little work on it this winter
Old November 2nd, 2017, 02:43 PM   #5953
Did some math. I need to narrow the tunnel 3" for 24" of length to get the seats to fit properly. Going to lob off the front head and then get the IRS cups put in. 3rd set I've done too!
Old November 3rd, 2017, 03:11 PM   #5954
Lobbed off the front, started on the left IRS cup.
Old November 3rd, 2017, 05:44 PM   #5955
vinayak
vinayak's Avatar
Not VR but had these resurfaced. Hopefully I can get this Impreza on the road soon so I can sell it to fund another VR build.
Responding to that email does not magically take your response, sign into the forum for you and miraculously place your message into the recipients PM inbox. Nor does it magically place your response into a thread you have subscribed to on the Cutting Board, etc.
vinayak is offline   Reply With Quote
Old November 3rd, 2017, 09:39 PM   #5956
Wow, 4 valve OHC. Too bad you can't adapt 'em to an air cooled VW.
Old November 3rd, 2017, 10:52 PM   #5957
Hmmmm
Old November 4th, 2017, 06:00 AM   #5958
vinayak
vinayak's Avatar
They are Subaru heads. I actually have a 98 Subaru EJ25 waiting for my VR build.
Old November 4th, 2017, 10:20 AM   #5959
That's cool! Brian, the owner/operator of a bicycle shop a quarter mile or so from here, runs a Subaru engine in his Vanagon. It's his daily driver, shop van, and he swears by it.
Old November 4th, 2017, 07:57 PM   #5960
vinayak
vinayak's Avatar
I'm just in the planning stages right now. I bought a spare 98 Legacy Outback wagon for the lift bits for the Impreza and just to have some extra parts if my Legacy breaks. It is going to be a lot of work but worth it in the long run. I am also planning airbags.
Old November 7th, 2017, 12:11 AM   #5961
Got the old chassis I built out from under the Coyote and started on the left IRS cup. Didn't realize how heavy I made stuff!
Old November 7th, 2017, 08:58 AM   #5962
To keep the center of gravity low, I presume?
Old November 7th, 2017, 09:56 AM   #5963
Mostly to keep it as a sports car and not a Sherman tank!
Old November 8th, 2017, 08:49 PM   #5964
Got most of the left side ready for welding. Cut the right side to match but have to fit it tomorrow. Need to get this welded up before it gets below freezing. I'm already pushing it with welding in the 40's.
Old November 9th, 2017, 11:19 AM   #5965
Been looking at my design for the Coyote. I was going to run the radiator up front but I got to thinking; this car isn't going to be raced, no SCCA, no land speed records; just a nice driver. So I think I'll just put the radiator behind the seats and the gas tank behind that. It'll save me routing 20 feet of coolant tubing and keeping things simpler. And if I want to change it, I can.
Heading out to weld...
Old November 9th, 2017, 03:45 PM   #5966
IRS cups tacked in. Bolting up the arms tomorrow to mock stuff out. Need to make some fake shocks to hold the ride height.
Old November 11th, 2017, 10:12 AM   #5967
Got the chassis in the shop somehow, under the Coyote frame and on jackstands. Bolted in the springplates (no bars for now) and got the arms on. Actually found the right socket for the lugnuts and got the wheels on. Need to get my temp fake shocks on to set the ride height. Have to clean the shop as I'm going to have sparks flying soon!:wel der:
Old November 22nd, 2017, 09:28 AM   #5968
Santa and his brown truck arrived yesterday. Brought the interior and upholstery for our T3. Since it's 24*F out, time to work in the basement.
Old November 24th, 2017, 10:31 PM   #5969
Worked on the driver's seat yesterday and got the window crank rebolted, the door panel on and the start of the carpet going in.
Also found out my Mustang II front end is coming from Speedway next week!
Old November 25th, 2017, 07:06 AM   #5970
Got mine running again yesterday. "Rebuilt" the Weber progressive about a week ago. Wasn't terrible, but did have some varnish in it from sitting. It has been messed with over the years, but it works for now.
Also finally got the steering situation under control. The P.O. had a horrible cobbled together 7" extension, so I replaced it with a proper 10" unit with a brace, and a steering kit from Fab 104.
Since the steering was so boogered up, the steering kit didn't quite fit. Was a little bit too short. So I cut the input shaft off the old steering box and made it fit in the steering shaft. Added the spherical bearing, and I'm good to go.
Drove it to the mailbox with only the ebrake. No stinger, just the header. Crazy loud. I was so happy to drive it again after like a year and a half.
And I installed my new hood ornament
Old November 25th, 2017, 09:30 AM   #5971
Good to see she's heading back toward the road. 'Nuthin' like a short drive to get ya motorvaited. New front end looks great....are those,um, 'air shocks?'
Old November 25th, 2017, 02:45 PM   #5972
You should see the rear. Driver's side is only attacked at the bottom. So only one shock, effectively, on the car. Had the wrong front wheel bearings. Old are 29mm id, new ones are 27mm. Oh well, driver's side front is missing the small spring. So I'll head up the road to Fisher Buggies Monday.
Before daylight savings time made me quit, I put the stinger back on, and took the front end adjusters back down. I love the look, but I know I'll die if I drive it like this daily.
Old November 25th, 2017, 04:17 PM   #5973
Die from grinning? Great looking machine!
Old November 25th, 2017, 10:27 PM   #5974
Dude, I was more excited when it fired up than I was when I was offered a job last week.
Old November 26th, 2017, 09:50 PM   #5975
Carpet almost totally in. Seats are getting upholstered in the basement. They are so damn hard to do!!!!!
what did you do, yesterday
