Threads: 32,423
Total Online: 207
- by jorez
Old March 13th, 2018, 05:42 AM   #6001
I had my fire suppression go off on my food trailer. Just as I opened, so I spent half the day cleaning. Then brought it to the installer and paid him $1000 to to refill and reset. I guess those cold days when I turn the fan off fatigued the links and one failed. Lesson learned.
Old March 13th, 2018, 05:10 PM   #6002
Wow! That Sucks Big time! Shouldn't be that easy to set it off by "stressing" it... the installer should do something to remedy that situation and prevent it from happening again as well as pay to do it all...
Old March 14th, 2018, 04:52 AM   #6003
I was running the fan very little. Being still cold out outside, it was my heat. I froze yesterday and ran the 100% of the time. Does suck!
Old March 14th, 2018, 11:52 AM   #6004
Sounds like faulty sensors to me, but I admit I'm not an expert. Still, this does not sound like it should have happened.
Old March 14th, 2018, 12:00 PM   #6005
Well, I think the guy said the links are good to 240. The hood gets real hot with the fan off. The fryer is set at 350. With the fan on in this cold weather, the hood is cold to touch. The links are up in the hood behind the grease filters. The whole system is manual with cable tension. Link breaks, system fires. It's just a little soft metal nub that holds it from firing. Simple and sucks. Lol.
Old March 22nd, 2018, 08:13 AM   #6006
Square
Square's Avatar
dropped my seats of at the sand blasters 1/3 is good to go, 2/3 needs repairing
Old March 25th, 2018, 08:58 PM   #6007
Took Rosie for her first drive of 2018. Started right up!
Old March 25th, 2018, 09:17 PM   #6008
Old March 25th, 2018, 10:22 PM   #6009
Have to seal a few more spots that let air and water in and tighten the steering box. Got so much play in the wheel!
Old March 30th, 2018, 04:46 PM   #6010
Just put retractable 3 point seatbelts in Rosie. Had to make a custom bracket on the bottom to hold both points. Back is killing me and the weather is damp and cold. Felt good to actually DO something though!
Old March 31st, 2018, 12:48 AM   #6011
YelLowBug
YelLowBug's Avatar
bought some parts,
bought some wrong parts
bought some more parts and found the right parts
so i ordered those to...
so today i got to return parts and if i get shop credit i have to buy some more parts...
so that was my day and gonna be my day.. wel part of it
driving the YelLowBug;
Old March 31st, 2018, 09:23 AM   #6012
'Been there, had that done to me.' Well, partly anyway.
Old March 31st, 2018, 10:19 PM   #6013
Parts for the welder arrived today. Now I get to plan out my angle of approach I disassembled the foot pedał to get a better sense of what wires go where. I figured out how to wire up 4 of the five wires.
Old April 2nd, 2018, 07:58 PM   #6014
Just got a lead on a 1974 semi-auto Ghia, original owner, 47,000 original miles, new engine but doesn't run. I need it like a hole in the head, but what the hell, right?
Old April 2nd, 2018, 08:37 PM   #6015
Back in 85 when I was replacing all the front suspension parts on my 74 Cutlass, I started off with the tie rod ends, the inners fit but the outters didn't, brought em back along with my original parts, turns out somebody swapped the parts from a Ford into the Olds box, they did the same thing with the ball joints, uppers were right but the lowers were wrong, same thing, somebody swapped the parts into different boxes, was the biggest PITA thing I ever did until I bought a starter for the same car in 89 from AutoZone, I splurged for the one with the lifetime warranty, after the 4th one went bad I took it back and asked for my money back, I quit buying parts from there when Oriely's opened up a half mile down the road, the only time I buy stuff from them is if it's a Sunday, otherwise I go to the place that opened up in 1962, I don't know what I'm gonna do if they ever close, they have always treated me right
Old April 18th, 2019, 05:33 AM   #6016
Clutch cable, freshened up the pedals and installed the front sway bar. Oh yeah, and a little test drive.
Old April 18th, 2019, 10:21 AM   #6017
During the "little test ride" were there long smoky burnouts?
Old April 18th, 2019, 12:03 PM   #6018
One attemp with wheel hop. Chirped second though. I need to make a better front mount for the trans. That 73 and up style suck.
Old April 18th, 2019, 05:42 PM   #6019
Old October 5th, 2019, 09:05 PM   #6020
It tracked down a wiring problem with my tail lights to the replacement turn signal switch I replaced the sixty year old original switch with two years and twenty one thousand miles ago. After some tinkering and careful cleaning with the old switch, it now seems to be working. Sigh.
Our crappy Ethanol blend fuel seems to be messing with the new carb after installing a new fuel tank, lines, fuel pump, etc. just over a year ago. Left idle mixture screw doesn’t work. Yup, I pulled it and blew out the port with compressed air. Off idle the truck goes like gang busters. So tomorrow off comes the ‘new’ 650 Eldebrock for a look see.
Old October 5th, 2019, 09:06 PM   #6021
Oops, I meant one thousand miles ago.
Old October 6th, 2019, 07:49 AM   #6022
Been busy building the chassis for my coyote. Heading over to canada soon to get the body!
Old October 7th, 2019, 04:48 AM   #6023
kustomkreep86
kustomkreep86's Avatar
Last week, the weather was typical for Canada in the fall. Rain, rain, and more rain. Doesn't mix will with no fenders...haha so not much cruising happening. I think some fenders are getting made this winter. But it was nice yesterday so my buddy and I managed to get some cruising in. Grabbed these cool shots while we were out.
Build...Break...Fix...Repeat
Old October 7th, 2019, 09:47 AM   #6024
It’s great seeing Frankie out and about! Are you going to get him some rain goggles just in case?🤔
Old October 16th, 2019, 08:55 PM   #6025
Rain and no fenders never stopped me, this is the first year that I haven't put less than 4000 miles on my Volksrod since I got it driving in 2011
I don't think I've put over 50 miles on it this years
what did you do, yesterday
