Total Online: 632
Old March 1st, 2009, 05:57 PM   #1
Default Beam Endplates etc. in CAD.
Re:: For the Tech Bin?
I thought I'd share these here too. Free to use on your own risk.
Thickness recommended for the endplates 10mm.
Baywindow endplates.dxf
Bayewindow endplates.pdf
Works for both early and late bays.
Splitbeam to baywindow.dxf
Splitbeam to baywindow.pdf
This one works both in splits and baywindows. In baywindows giving an extra drop in the front without changing the splitbeam suspension much.
Split beam endplates.dxf
Splitbeam endplates.pdf
The shocktower mounts differ some on the endplates. They are moved up but still fit under stock wheelwells.
Caster is increased to -3degree angle to improve the driveablity with a little rake too.
Finally these Horseshoes also in 10mm thick plates:
Horseshoes for baywindow.dxf
Horseshoes for baywindow.pdf
Type-1 pre-66 endplates.dxf
Type-1 pre-66 endplates.pdf
Old March 1st, 2009, 07:55 PM   #2
bugroadster
bugroadster's Avatar
Default Re: Beam Endplates etc. in CAD.
ive got beam plates for sale in the usa but i like the paterns so im going to put them in the files thanks
"When everything seems to be going against you, remember that the airplane takes off against the wind, not with it." - Henry Ford
bugroadster is offline   Reply With Quote
Old March 1st, 2009, 11:37 PM   #3
That's Reall cool of you to share them with us Heb! Thanks!
Steve X.
Old March 28th, 2009, 10:37 AM   #4
Hmm. Seems like the lower tube on my Baywindow endplate drawings is slightly too low. I have to doublecheck that and correct if necessary.
Not that much that it affects anyway negative.
Sorry...
Old March 31st, 2009, 12:22 AM   #5
Bay endplate files corrected and type-1 endplate files added.
Old March 31st, 2009, 04:57 AM   #6
I thought you might have had the Balljoint end plates in there... Not just link pin ones... Looks like I'll have to get off my ass & measure my own then...
Old March 31st, 2009, 06:07 AM   #7
Yes, I'm not sure I will be making those either as those need to be made in several pieces welded together...
Old March 31st, 2009, 06:49 AM   #8
I was thinking more along the lines of making them like the l/p ones. I would think you could do the same & use l/p shocks for it... Just a thought... I don't kow if it would work, but, it was an idea I had.
Old March 31st, 2009, 09:23 AM   #9
Might work. But I will not and am not able to do the research if it is doable. First of all I dont own a balljointbeam to measure from.
Old September 13th, 2009, 07:56 PM   #10
cliff@brownbags
awesome post! do you have it for a 67+ beetle?
cliff@brownbags is offline   Reply With Quote
Old September 14th, 2009, 01:51 AM   #11
Sorry, I dont have endplate files for post-68 bugs. Might be possible to make ones that would be as mentioned above.
Have to look into that some day.
Old September 14th, 2009, 05:27 PM   #12
cliff@brownbags
im about to start building my own beams this winter , and once my cad guy gets them ill post up for you guys.
Old November 13th, 2011, 09:42 AM   #13
Cogwheel .dwg and .dxf files.
http://www.fvwa.sitefactory.fi/data/2.dwg
http://www.fvwa.sitefactory.fi/data/9.dxf
Old November 13th, 2011, 10:44 AM   #14
They work but need a little tweaking for cutting.
Old November 21st, 2011, 04:30 PM   #15
whozawhat
whozawhat's Avatar
they came out fine
Old May 17th, 2020, 12:48 PM   #16
Just want to announce that these files have not been available online for several years as the web host was shut down.
Please check my Facebook if you need help.
https://www.facebook.com/HebsterWerk...3162320702330/
bay endplate
