Total Online: 699
Old April 11th, 2009, 12:17 PM   #1
Default wiring diagrams
Re:: other sites and threads located here
it's been suggested (thanks Walt) to post some in here. So here's the first one
http://www.vintagebus.com/wiring/index.html
Any you come across, please post in this thread.
(I know, search function is funked, so this is how we fix it )
Old April 11th, 2009, 12:59 PM   #2
Default Re: wiring diagrams
generator to altenator
Old April 11th, 2009, 01:00 PM   #3
samba
http://www.thesamba.com/vw/archives/info/wiringt1.php
from here you can also view type2, type 3, ghia and thing,
click links on top of page
Old April 12th, 2009, 04:40 PM   #4
cant recall where this one came from, but here it is
Old February 22nd, 2010, 12:26 PM   #5
Default Re: wiring diagram? anyone?
Here is a simplified version that might be more what you're looking for.
Buggy Schematic
Old May 9th, 2010, 05:50 AM   #6
cruiserbug
cruiserbug's Avatar
Thank you, bud
was going to ask for this, but i dont need to now cuz i guess u read mind.
im rewire my 72 super bug and hopefully everything go well
cruiserbug is offline   Reply With Quote
Old June 28th, 2010, 03:24 PM   #7
Zedmon
Here is a great wiring diagram that I found.
http://www.chircoestore.com/catalog/...p?topic=3819.0
Zedmon is offline   Reply With Quote
Old January 1st, 2011, 01:38 PM   #8
wrenchmonkey
wrenchmonkey's Avatar
Hey Mike,
That diagram pictured above a few times for alternator installation is based upon a custom switch and light as they've drawn it. Our Vdubs, if running stock ignition switches as early as your avi/name won't have the "accessory" position or that type of "idiot light".
If you got OG wires in your bus then do this:
B+ on alt ---> battery positive (+). In the diagram it's jumped to the battery via the starter's input but it could be direct wired too since you have a bus and the battery is right there.. Just need to make the wire of sufficient size (6mm is/was stock).
D term on alt ----> to blue-green wire from OG voltage regulator. (this will need an extension usually). It looks like the oil pressure wire but way shorter in the bus.
The idiot lights on the OG guage(s) are positively (+) powered when key goes to "On" position and they are grounded (-) via the engine case by oil pressure switch and by voltage regulator to light-up. The D terminal on the alternator will provide the ground to that idiot light when it's not spinning (ie: not running or if you throw a belt).
Hope that made sense and answered your question.
jeff
http://www.revolks.com/
wrenchmonkey is offline   Reply With Quote
Old January 3rd, 2011, 07:54 PM   #9
1stratrodvw
what if the body is wired for alt but want to run gen
1stratrodvw is offline   Reply With Quote
Old January 26th, 2011, 03:36 PM   #10
69rat*tat2r
you have to run a voltage regulator.. the df wire on the alt. follow to where you want to mount it cut it. mount the wire from the df of the alt. and put it on the df of the genartor . the remainder of the df wire goes to the light. which get mounted to the opposite side of the volt reg. then the battery post ( b+) goes to the (b+) side of the volt. reg. thats where on the other corner has two spades. one to the battery and the other to the fuse panel...
69rat*tat2r is offline   Reply With Quote
alternator diagram, gen to alt, wiring diagram
