Total Online: 619
Old August 4th, 2009, 01:49 PM   #1
Default Engine threads
Some past threads on engines. These cover most major topics and questions. Please feel free to bring these up and add more info or ask questions. These will come up in the cutting board, not here in the tech bin, so look for replies there. These are LINKS only. This thread is for links only, any questions you have and not provided in one of these links, please ask in the Cutting forum.
You will find lots of info in shoptalkforum.com
what drivetrain/combo are you running?
http://www.volksrods.com/forum/showthread.php?t=21449
what's you mpg?
http://www.volksrods.com/forum/showthread.php?t=8470
performance, can't drive 55
http://www.volksrods.com/forum/showthread.php?t=14140
what are you running?
http://www.volksrods.com/forum/showthread.php?t=24885
what engine should I get?
http://www.volksrods.com/forum/showthread.php?t=12098
show off your engine compartments
http://www.volksrods.com/forum/showthread.php?t=10674
engine companies
http://www.volksrods.com/forum/showthread.php?t=16578
biggest engine displacement
http://www.volksrods.com/forum/showthread.php?t=26737
painted engine case/block
http://www.volksrods.com/forum/showthread.php?t=24626
engine cleaning
http://www.volksrods.com/forum/showthread.php?t=24510
engine building 101 (tips tricks etc)
http://www.volksrods.com/forum/showthread.php?t=23319
engine tins
http://www.volksrods.com/forum/showthread.php?t=10345
cooling
http://www.volksrods.com/forum/showthread.php?t=14968
http://www.volksrods.com/forum/showthread.php?t=11911
Old September 26th, 2009, 06:40 AM   #2
Default outside links
torque specs that may not be listed in all manuals
Courtesy of chirico site
http://chircoestore.com/wordpress/?page_id=23
Torque Specifications for type 1 3
Type 1 3
Part - ft-lb size (dia x pitch)
Connecting rod nut 24 m 91
Connecting rod capscrew 32 m 91
Crankcase nut 14 m 8
Crankcase nut 25 m 121.5
Cylinder head nut 8mm 18 m 8
Cylinder head nut 10mm 23 m 10
Rockershaft nut 18 m 8
Heat Exchanger at head 14 m 8
Muffler Clamp bolts 7 m 6
Intake manifold nut 14 m 8
Preheat-flange bolt 7 m 6
Oil Pump nut 14 m 8
Oil Pump nut 9 m 6
Oil Drain plug 25 m 141.5
Oil Strainer nut 5 m 6
Oil cooler nut 5 m 6
Oil filler gland nut 40
Flywheel Gland nut 235 m 281.5
Clutch bolt 18 m 81.5
Sparkplug 25 m 141.25
Engine to trans nut 22 m 10
Crossmember bolt 18 m 8
Crossmember bolt 29 m 10
Generator pulley nut 43 m 121.5
Fan nut 43 m 121.5
Crankshaft pulley nut 32 m 201.5
Crossmember to body 18 m 8
Fan/Crankshaft pulley 94-108 m 201.5
interested in engine displacement?
http://www.msgulfcoastvwclub.org/TechPages/Tech6.html
engine, engine help
