Members: 17,342
Threads: 32,253
Total Online: 511
Newest Member: Weld
- by AMMO22
Old July 26th, 2008, 08:05 AM   #1
blacktruck
blacktruck's Avatar
Default hardener + rustoleum?
what kinda ratio or amount of hardener would work in a
gallon of rustoleum?
ultimate cheapskate that I am,I'll custom mix some grey
out of flat black and white.But I have no idea how many parts
of each to put in the gun
nut up or shut up
Old July 26th, 2008, 09:19 AM   #2
staynedglass
staynedglass's Avatar
Default Re: hardener + rustoleum?
i just cut it with 50-50 paint and acetone. be careful how you mix. i know that i got the perfect color in the can but it dried hella lighter than what i wanted.
Originally Posted by staynedglass View Post
click for die cut vinyl decals Only $4.5shipped. PBR logos, Vw war eagle,lots more http://www.volksrods.com/forum/showt...339#post460339
staynedglass is offline   Reply With Quote
Old July 26th, 2008, 10:00 AM   #3
blacktruck
blacktruck's Avatar
so the acetone is the hardener?
funny coincidence,mom's manicurist retired recently and gave her a gallon of acetone that she gave to me
nut up or shut up
Old July 26th, 2008, 10:03 AM   #4
Acetone is a solvent,definitely not a Hardener.
I think John Deere sells Hardener to go with their paint.Same with TSC.
Maybe check the instructions for them,and use the same amount.
Old July 26th, 2008, 10:07 AM   #5
jroymcd
jroymcd's Avatar
when you thinking about doing it?
jroymcd is offline   Reply With Quote
Old July 26th, 2008, 10:21 AM   #6
blacktruck
blacktruck's Avatar
not right away,gotta get some masterseries first to seal up some rusty bits,and collect the felts and stuff for the windows.
the bumpers and removeables will probly get done before the rest so I can reassemble it asap after I get it done
nut up or shut up
Old July 26th, 2008, 10:39 AM   #7
cdscowboy
cdscowboy's Avatar
Yeah you need an activator, and acetone won't work for ya. Go to your local paint store (automotive, of course) and bring the can of what you've got. They should be able to set you up. NAPA's got pretty cheap paint stuff that's decent.
1970 T1
Build
www.99westcustoms.com
Old July 26th, 2008, 10:40 AM   #8
Feuer_kampfer
Feuer_kampfer's Avatar
The acetone is just a reducer/solvent. The rustoleum has the hardner built in.
Feuer_kampfer is offline   Reply With Quote
Old July 26th, 2008, 11:01 AM   #9
Just a question not an opinion.
Why use rustoleum and not a single stage type paint?
Old July 26th, 2008, 12:05 PM   #10
If it had hardener in it,the stuff would go hard in the can before you bought it.
Old July 26th, 2008, 12:05 PM   #11
jroymcd
jroymcd's Avatar
ultimate cheapskate
left over from his last paint job
Old July 26th, 2008, 12:15 PM   #12
If you bring Rustoleum with you they will most likely be of much help.
As they are locked into their own little world with blinders on and only what they sell will work with what they sell. Alot of people never think that some products can work for things other then what they are not intended for and the fact that it's cheap paint means right off that it won't work.
We have a Auto paint stroe connected to the building I work in and when asked for Enamel hardener the response was What brand of paint. I told them it doesn't matter I am just looking for generic enamel hardener. the response was well it won't work unless its the same name brand and we don't carry anything like that. We need to know what system and the part numbers beofre we can sell it to you.
Get them on the phone and say you have some enamel paint with no label and you want to use it on a Bicycle, then say I need Enamel hardener and everyone else i talked to says you can help me. Also I am gonna be doing a car project so I will be checking a price on some primer and asking for advice......
Now you got them on the hook for potential future sales and their reptutation is in play. they will be more helpful.
Old July 26th, 2008, 12:21 PM   #13
jroymcd
jroymcd's Avatar
Duplicolor now sells paint pre mixed and ready to put in a gun. its only 20. a can. might take two cans? could do a decent paint job under 40. they got about 6 colors to chose from and you can get it at most local kragens etc.
http://www.duplicolor.com/products/paintshop.html
Old July 26th, 2008, 12:34 PM   #14
From what I understand: Rustoleum is an enamel, which I think is cured when water is evaporated from it?? No need for a hardener, but some people put hardener to make it cure quicker, etc. Epoxy, urethane, polyurethane, and some other types of paint is cured by a chemical reaction (paint + hardener = chemical reaction). So not all paints require a hardener
Old July 26th, 2008, 12:46 PM   #15
People add hardener in it to make it harder. Adds quite a bit of strength to it and turns OK product into a much better one at a much cheaper price.
Old July 26th, 2008, 03:20 PM   #16
rodderdan
I used hardener with Rustoleum rusty metal primer,the brownish stuff.I don't know what brand it was or how much I used though.A friend had it in the shop and it was cold out so we dumped what he had in with 2 quarts of Rustoleum.Turned out good and it seems to have the made the paint harder.It's been on the car about 6 yrs now,still looks good and cleans up nice.
Old July 26th, 2008, 08:06 PM   #17
blacktruck
blacktruck's Avatar
aha!
so dan any recollection on what size container that guy had that y'all threw in there-size of an inflight booze bottle?
bottle of hot sauce?
just get me in the ballpark here
Jon you are so right,ya gotta let them help you.If it means
BS so they feel OK,so be it.
nut up or shut up
Old July 26th, 2008, 09:42 PM   #18
rodderdan
aha!
Nope,just want to let you know it worked.The Rustoleum was $7 a quart and the hardener was free.Don't remember the amount or brand of hardener we used.You can always mix a small amunt and spray some junk metal with it.If it works mix a larger batch.
Old July 27th, 2008, 04:46 AM   #19
Old Gold
The hardener cuts the drying time to about 20 minutes "dry to touch". Without it it takes about 10 hours for "dry to touch". The mix ratio is 1 pint per 1 gallon. Reduce with acetone to spray consistency. Mix enough to spray all you want. Pot life with hardener is 8 hours.
Old Gold is offline   Reply With Quote
Old July 27th, 2008, 07:29 AM   #20
blacktruck
blacktruck's Avatar
hello and thank you
nut up or shut up
Old August 29th, 2008, 04:35 PM   #21
shok
would the same go for the john deere paint? meaning you can add hardner to speed shit up, or don't add hardener and just wait, but it will dry? I only just found a fairly local place to get the deere stuff and might try it on my baja.
shok is offline   Reply With Quote
Old August 29th, 2008, 05:11 PM   #22
cdscowboy
cdscowboy's Avatar
I'm pretty sure the John Deere needs hardener. We've got drips on our mixing table that are still flexible/soft after a week...
1970 T1
Build
Old August 29th, 2008, 06:26 PM   #23
Spray-Bomb
Spray-Bomb's Avatar
I sprayed my car with Rustoleum & just reduced it with acetone & shot it
I havent had any problems with it, & for the $$$ would totally do it again
If it comes in a box, It's not custom !
Intro
Spray-Bomb is offline   Reply With Quote
Old August 29th, 2008, 09:02 PM   #24
blacktruck
blacktruck's Avatar
saw some stuff at the hardware store called "japan drier"
did a little reading about it and it sounds like the same kinda stuff as hardener
after I collect some $$ I'ma do a little test
nut up or shut up
Old August 29th, 2008, 09:42 PM   #25
dt113
dt113's Avatar
John Deere paint is an epoxy paint. Use the J. Deere hardner with it. Painted a truck with it about 8 yrs ago, and it still looks good.
1 gal of paint is around $25.00. Don't remember on the hardner.
