Threads: 32,399
Total Online: 702
Old June 9th, 2020, 01:52 PM   #1
mazdawg78
mazdawg78's Avatar
Default ford wire wheels
anyone running 16" Ford wires? If so,what size tires? I want radials but the sizes convert into temporary use or trailer tires. I want to stay away from junk cokers because I plan actually driving my car.
mazdawg78 is offline   Reply With Quote
Old June 12th, 2020, 02:42 PM   #2
Default Re: ford wire wheels
Might get more replies if you change
the Subject to "16" tires ?" or similar.
Old June 12th, 2020, 04:09 PM   #3
Iíve never needed to use ĎCokerí brand tires. But have seen then at a couple of local car shows. I take it thereís a problem with them?
Old June 12th, 2020, 04:10 PM   #4
One of our members had a set of ford wire wheels with Motorcycle tires on them... pretty sure they were radials... but not 100% as he was on the European side of the water.
Old August 20th, 2020, 10:48 PM   #5
Go look around the hot rod world. Iím certain thereís a few model A hot rods running wires that you can deem information from. Motorcycle tires are an option as mentioned.
